PNY GeForce GTX 970 XLR8 4GB
in GPU, Reviews
PNY XLR8 GeForce GTX 460 1024MB GDDR5 PCI-Express 2.0 DVI-I+DVI-I+HDMI mini Overclocked Graphics...
PNY XLR8 GeForce GTX 460 1024MB GDDR5 PCI-Express 2.0 DVI-I+DVI-I+HDMI mini Overclocked Graphics Card VCGGTX4601XPB-OC
PNY XLR8 GeForce GTX 580 1536MB GDDR5 PCI-Express 2.0 DVI-I+DVI-I+HDMI mini Graphics Card...
PNY XLR8 GeForce GTX 580 1536MB GDDR5 PCI-Express 2.0 DVI-I+DVI-I+HDMI mini Graphics Card VCGGTX580XPB
PNY GeForce GTX 1650 4GB GDDR6 Dual Fan Graphics Card
15. PNY GeForce GTX 970 XLR8 4GB – Overclocking
  • 1. PNY GeForce GTX 970 XLR8 4GB – Intro
  • 2. PNY GeForce GTX 970 XLR8 4GB Testing Methodology
  • 3. PNY GeForce GTX 970 XLR8 4GB – Synthetic Explained
  • 4. PNY GeForce GTX 970 XLR8 4GB – Sleeping Dogs
  • 5. PNY GeForce GTX 970 XLR8 4GB – Metro: Last Light
  • 6. PNY GeForce GTX 970 XLR8 4GB – BioShock Infinite
  • 7. PNY GeForce GTX 970 XLR8 4GB – Tomb Raider
  • 8. PNY GeForce GTX 970 XLR8 4GB – Batman Arkham Origins
  • 9. PNY GeForce GTX 970 XLR8 4GB – Real World In-Game Explained
  • 10. PNY GeForce GTX 970 XLR8 4GB – Battlefield 4
  • 11. PNY GeForce GTX 970 XLR8 4GB – Assassins Creed: Black Flag
  • 12. PNY GeForce GTX 970 XLR8 4GB – CoD: Ghosts
  • 13. PNY GeForce GTX 970 XLR8 4GB – Crysis 3
  • 14. PNY GeForce GTX 970 XLR8 4GB – Temp, Noise and Power
  • 15. PNY GeForce GTX 970 XLR8 4GB – Overclocking
  • 16. PNY GeForce GTX 970 XLR8 4GB – Summary and TL;DR
  • 17. PNY GeForce GTX 970 XLR8 4GB – Score Card
  • 18. PNY GeForce GTX 970 XLR8 4GB – Closing Statement
Overclocking
To discover our PNY GeForce GTX 970 XLR8 4GB sample’s overclocking abilities we used EVGA’s Precision X software and began raising power and thermal thresholds to the maximum allowed and then increased the voltage also to the maximum permitted. Then using Unigine’s Valley benchmark we began stability testing.
oc_bio_10
oc_cry_10
oc_bio_14
oc_cry_14
We really did have high hopes for this card and while there is still some headroom to be found, we did walk away a bit disappointed by this PNY XLR8’er card. In the past PNY XLR8’s never let us down and provide ample amount of overclocking headroom. Sadly, because PNY did cut corners on the cooling solution this 970 will actually thermally limit itself long before you reach the actual physical limits of the Maxwell architecture. This is a shame as it is such a cool running chip, but the blower is basically only good enough at keeping a stock 970 cool. Hopefully at some point PNY will release an ‘OC’ or ‘OC2’ version that negates this cooling problem and allows for some insane overclocks.
On the positive side we did manage to reach a peak of 1328MHz -or 150Mhz over the factory ‘stock’ setting. This is an additional 12.7% of free performance that really will not take all the much effort to unlock. On the memory side of the equation we were able to boost the memory to an effective 7600Mhz, which is a 8.4 percent improvement over the card’s default 7010Mhz setting. This increase in GPU and memory performance does translate to a couple extra average frames per second and an a additional frame or two on the all-important minimum frames per second scale.
Page 15 of 18
Tags: Gaming Graphics cardGTX 970GTX 970 XLR8PNY GeForce GTX 970 XLR8 4GBXLR8
MiniTool Partition Wizard Pro
