Orico USB to M2 adapters Review
Small form-factor, big performance
ORICO M.2 SATA SSD External Enclosure Tool-Free USB 3.1 Type-C Adapter, Support NGFF(SATA Based)...
ORICO M.2 SATA SSD External Enclosure Tool-Free USB 3.1 Type-C Adapter, Support NGFF(SATA Based) M.2 2280 2260 2242 2230 SSD Enclosure Adapter-(TCM2F, Black)
ORICO NVME M.2 to Type-C USB3.1 Gen2 10Gbps Transparent External Solid State Drive Adapter...
ORICO NVME M.2 to Type-C USB3.1 Gen2 10Gbps Transparent External Solid State Drive Adapter Enclosure for 2280 2260 2242 2230 PCI-E M2 M-Key SSD, USB Type C Converter Case (TCM2-Blue)
ORICO M.2 SSD Enclosure 6Gbps M.2 SATA to USB-C Adapter USB3.1 Gen1 for B-Key/B+M Key SSD...
ORICO M.2 SSD Enclosure 6Gbps M.2 SATA to USB-C Adapter USB3.1 Gen1 for B-Key/B+M Key SSD (2230/2242/2260/2280) , M2 External NGFF SATA SSD Case Reader with UASP, Trim, Smart, SSD Max 4TB-MM2-Green
4. Testing Methodology
  • 1. Small form-factor, big performance
  • 7. Score Card & Summary
Testing external storage designed for use as a portable device is not like testing solid state drives, or even compact storage devices like ‘thumb drives’. These devices have very unique standards and have been optimized for highly specialized roles. For this reason, we have chosen to a combination of synthetic and real-world tests that will show the intended customer base what the real strengths and weaknesses of a product line are.
To this end we have chosen ATTO, AS-SSD, and Crystal DiskMark for our synthetic test suites. However, we have opted to not include any deep queue depth testing. Instead only the sequential, medium size, and single queue small file size tests are run. ATTO’s full range of file sizes will be included but this is only so that consumers can see the performance curves a given storage device offers. Furthermore, we will be significantly discounting any results under the 8K mark in ATTO.
For real world we have opted for our usual real-world transfer test. This is a two-part test. The first consist of timing how long a single 30GB (30 Billion bytes) rar file takes to copy to and then from the devices. The second consists of timing how long it takes to copy to and then from 15GB (15 Billion bytes) worth of small files (from 100kb to 200MB) with a total 36,000 files in 1200 subfolders.
Orico USB to M2 adapters Review 22
Page 4 of 8
Tags: NVMEnvme to usboricopcmrportable nvmereviewSeagateSilicon PowerSSDstorageusb 3.1 to nvmeWD
Lexar 3400x Cfast 2.0
July 21, 2015
Intel Innovation 2023
September 19, 2023
