A fully matured Suprim
in GPU, Reviews
MSI Gaming RTX 5080 16G Gaming Trio OC Graphics Card (16GB GDDR7, 256-bit, Extreme Performance:...
MSI Gaming RTX 5080 16G Gaming Trio OC Graphics Card (16GB GDDR7, 256-bit, Extreme Performance: 2715 MHz, DisplayPort x 3 2.1a, HDMI 2.1b, NVIDIA Blackwell Architecture)
MSI Gaming RTX 5080 16G Inspire 3X OC Graphics Card (16GB GDDR7, 256-bit, Extreme Clock TBD MHz,...
MSI Gaming RTX 5080 16G Inspire 3X OC Graphics Card (16GB GDDR7, 256-bit, Extreme Clock TBD MHz, DisplayPort x 3 2.1a, HDMI 2.1b, NVIDIA Blackwell Architecture)
18. Temperature, Noise, and Power Analysis
  • 2. Packaging & Accessories
  • 6. Closer Look p.4
  • 8. Overclocking
  • 9. AC: Mirage, Cyberpunk 2077
  • 10. Battlefield 5, CoD: MWII
  • 11. Crysis 3, Far Cry 6
  • 12. GTA V, Hitman 3
  • 13. Metro Exodus, S.T.R.
  • 14. The Division 2, Watch Dogs: Legion, Witcher 3
  • 15. Ray Tracing Performance
  • 16. Adobe PP & Blender
  • 17. DaVinci, Handbrake, Topaz AI
  • 19. Closing Thoughts
For all temperature testing, the cards were used in an open test bed environment. Ambient temperature was kept at a constant 20°C (+/- 0.5°C), and if the ambient room temperatures rose above 21°C or dropped below 19°C at any time, all benchmarking was stopped until proper temperatures could be normalized.
MSI GeForce RTX 5080 16G Expert OC Review 99
Sound Level Test Results
While everyone “hears” noise differently, there is one easy way to remove all subjectivity and easily compare different fans: use a sound level meter. This way you can easily compare the various fans noise envelopes without us coloring the results and see what fans fit within your personal comfort level. Of course, we will endeavor to try and explain the various results – which are taken at a 15 inch distance from the GPU’s fan(s) – to help you gain an even better understanding of how loud a cooler’s stock fan is, but even if you discount our personal opinions, the fact remains numbers don’t lie.
MSI GeForce RTX 5080 16G Expert OC Review 100
System Power Consumption
To obtain accurate results, we have connected the system to a Power Angle power meter that has in turn, been attached to a 1500-watt UPS. This ensures only 120-volt power is supplied to the PSU and removes any variances that could potentially crop up because of brownouts and power spikes.
In order to stress the video card, we have once again used Unigine’s Valley benchmark and ran it for 20 minutes to determine peak system power consumption. For idle results we have let the system idle at the Windows 10 desktop for 25 minutes and recorded the peak idle power consumption.
MSI GeForce RTX 5080 16G Expert OC Review 101
  • 8. Overclocking
Page 18 of 19
Tags: All-rounder GPUCompact GPUExpert OCFlow FROZR 2MSI GPU reviewMSI RTX 5080Professional GPUQuiet GPURTX 5080 ProArt alternative
Intel Gamer Days 2025 Kicks Off with Free Battlefield 6 Bundle
