The best value RTX 4000 released to date
in Reviews, GPU
16. Temperature, Noise, and Power Analysis
  • 6. Closer Look p.4 / Overclocking
  • 8. AC: Valhalla, Cyberpunk 2077
  • 9. Battlefield 5, CoD: MWII
  • 10. Crysis 3, Far Cry 6
  • 11. GTA V, Hitman 3
  • 12. Metro Exodus, S.T.R.
  • 14. Ray Tracing Performance
  • 15. Overall Performance comparison
  • 17. Closing Thoughts
MSI GeForce RTX 4060 Ti GAMING X TRIO 8G Review 80
Sound Level Test Results
MSI GeForce RTX 4060 Ti GAMING X TRIO 8G Review 81
System Power Consumption
To obtain accurate results we have connected the system to a Power Angle power meter that has in turn been attached to a 1500watt UPS. This ensures only 120volt power is supplied to the PSU and removes any variances that could potential crop up because of brownouts and power spikes.
MSI GeForce RTX 4060 Ti GAMING X TRIO 8G Review 82
Page 16 of 17
Tags: 4060tigaming x trioMSIMSI GeForce RTX 4060 Ti GAMING X TRIO 8GNvidiaRTX
Intel Unveils New Intel Arc Pro A60 and Pro A60M GPUs for Professional Workstations
