MSI GTX 980Ti Lightning: The Silent Assassin
in GPU, Reviews
MSI Gaming GeForce GTX 1660 Super 192-bit HDMI/DP 6GB GDRR6 HDCP Support DirectX 12 Dual Fan VR...
MSI Gaming GeForce GTX 1660 Super 192-bit HDMI/DP 6GB GDRR6 HDCP Support DirectX 12 Dual Fan VR Ready OC Graphics Card (GTX 1660 Super VENTUS XS OC)
MSI Computer Video Graphic Cards GeForce GTX 1050 TI GAMING X 4G, 4GB
MSI Gaming GeForce GTX 1660 Super 192-bit HDMI/DP 6GB GDRR6 HDCP Support DirectX 12 Dual Fan VR Ready OC Graphics Card (GTX 1660 Super Gaming X)
16. MSI 980Ti Lightning – Temperature, Noise, and Power Analysis
  • 1. MSI 980Ti Lightning – Introduction
  • 2. MSI 980Ti Lightning – Specs and Features
  • 3. MSI 980Ti Lightning – GeForce GTX 980Ti explained
  • 4. MSI 980Ti Lightning – A Closer Look
  • 5. MSI 980Ti Lightning – Testing Methodology
  • 6. MSI 980Ti Lightning – Sleeping Dogs (SGB)
  • 7. MSI 980Ti Lightning – Metro: Last Light (SGB)
  • 8. MSI 980Ti Lightning – BioShock Infinite (SGB)
  • 9. MSI 980Ti Lightning – Tomb Raider (SGB)
  • 10. MSI 980Ti Lightning – Batman Arkham Origins (SGB)
  • 11. MSI 980Ti Lightning – Battlefield 4 (RWB)
  • 12. MSI 980Ti Lightning – Assassins Creed: Black Flag (RWB)
  • 13. MSI 980Ti Lightning – Call of Duty: Ghosts (RWB)
  • 14. MSI 980Ti Lightning – Crysis 3 (RWB)
  • 15. MSI 980Ti Lightning – Witcher 3 (RWB)
  • 16. MSI 980Ti Lightning – Temperature, Noise, and Power Analysis
  • 17. MSI 980Ti Lightning – Overclocking
  • 18. MSI 980Ti Lightning – Performance Summary and TL;DR
  • 19. MSI 980Ti Lightning – Closing Statement
For Load tests, we ran Unigine’s Valley benchmark for 20 minutes.MSI GTX 980Ti Lightning: The Silent Assassin 49 Yes these numbers are correct. This magnificent beast keeps that highly overclocked Maxwell core humming along at downright cool temperatures. Though when you think about it, a heatsink and fan designed for 700 watts of heat shouldn’t have any problems with a 250w TDP card…but it still is bloody impressive to say the least.
Sound Level Test Results
While everyone “hears” noise differently there is one easy way to remove all subjectivity and easily compare different fans: use a sound level meter. This way you can easily compare the various fans noise envelopes without us coloring the results and see what fans fit within your personal comfort level. Of course, we will endeavor to try and explain the various results – which are taken at a 15 inch distance from the GPU’s fan(s) – to help you gain an even better understanding of how loud a cooler’s stock fan is, but even if you discount our personal opinions, the fact remains numbers don’t lie.
For Idle tests, we let the system idle at the Windows 7 desktop for 25 minutes and recorded the peak dB.
For Load tests, we ran Unigine’s Valley benchmark for 20 minutes and recorded the peak dB.MSI GTX 980Ti Lightning: The Silent Assassin 50 Even though this card is heavily its idle numbers are basically below ambient and its load numbers are not much higher than a whisper. This TriFrozr cooler really does work and work well.
System Power Consumption
In order to stress the video card we have once again used Unigine’s Valley benchmark and ran it for 20 minutes to determine peak system power consumption. For idle results we have let the system idle at the Windows 7 desktop for 25 minutes and recorded the peak idle power consumption.MSI GTX 980Ti Lightning: The Silent Assassin 51 Considering this card is heavily overclocked its slightly higher power consumption should come as no surprise. To be honest, what was surprising was how close it was to the Gaming 6G 980Ti as we would have thought it would use even more power!
Page 16 of 19
MSI R7 370 Gaming 2G
