Lexar XQD 2933
Lexar XQD 2933
Lexar Professional 2933x 64GB XQD 2.0 Card (Up to 440MB/s Read) w/Free Image Rescue 5 Software -...
Lexar Professional 2933x 64GB XQD 2.0 Card (Up to 440MB/s Read) w/Free Image Rescue 5 Software - LXQD64GCRBNA2933
Lexar 128GB Professional XQD 2.0 2933x Speed Rating Memory Card Model LXQD128CRBEU2933
$225.00
2 used from $225.00
as of March 26, 2026 1:53 am
Lexar Professional 64GB CFexpress Type B Memory Card, Up To 1750MB/s Read, Raw 4K Video...
Lexar Professional 64GB CFexpress Type B Memory Card, Up To 1750MB/s Read, Raw 4K Video Recording, Supports PCIe 3.0 and NVMe (LCFX10-64GCRBNA)
6. Lexar XQD 2933 – Test Results
  • 1. Lexar XQD 2933 – Introduction
  • 2. Lexar XQD 2933 – Specifications and Features
  • 3. Lexar XQD 2933 – Closer Look at the Lexar Professional 2933X XQD card
  • 4. Lexar XQD 2933 – Image Rescue 5
  • 5. Lexar XQD 2933 – Testing Methodology
  • 6. Lexar XQD 2933 – Test Results
  • 7. Lexar XQD 2933 – Score Card, Performance Summary & TL;DR
  • 8. Lexar XQD 2933 – Closing Statement
Synthetic Test Results
For synthetic tests we have used a brand new Lexar WorkFlow USB 3.0 card reader. The reason for using this particular card reader is not because of any brand favoritism, nor because the included micro-SD UHS-II reader is poor; rather we found the WorkFlow model to be one of the best card readers available today.
ATTO Disk Benchmark
Lexar XQD 2933 18 Lexar XQD 2933 19
Thanks to its PCIe, and not SATA foundation, the 2933x XQD card is phenomenally fast with all file sizes.
AS-SSD
Lexar XQD 2933 20 Lexar XQD 2933 21
Crystal DiskMark
Lexar XQD 2933 22 Lexar XQD 2933 23
Once again the new Lexar Professional XQD 2.0 2933X series is posting extremely good numbers – numbers that are a lot closer than the ‘2933X’ vs ‘3600X’ numbers would lead you to believe. Brilliant stuff.
Page 6 of 8
DuneCase
DuneCase
Corsair 5000D Review
