Promises Made. Promises Kept. Promises of a Better Tomorrow.
in Reviews, Processors (CPU)
11. winRAR & x264 HD
  • 2. Closer Look P.1
  • 3. Closer Look P.2
  • 4. Test Beds
  • 5. Musings on Overclocking
  • 6. Adobe Performance
  • 7. Blender & CineBench Results
  • 8. DaVinci & Handbrake
  • 9. POV-Ray & OpenSCAD
  • 10. SolidWorks & TrueCrypt
  • 11. winRAR & x264 HD
  • 12. AC:V & Borderlands 3
  • 13. CS: GO & Metro Exodus
  • 14. RDR2 & Tomb Raider
  • 16. Analysis of Mainstream Consumer CPU options
  • 17. Closing Thoughts
winRAR Benchmark
Intel’s 270K Plus & 250K Plus Review 35
x264 HD Benchmark
Intel’s 270K Plus & 250K Plus Review 36
  • 4. Test Beds
Page 11 of 17
Tags: Core Ultra 7 265Core Ultra 7 265KCore Ultra 9 285KCPU benchmarksCPUsDesktop Processorsgaming CPUsIntelIntel Core Ultra 200S PlusIntel Core Ultra 5 250K PlusIntel Core Ultra 7 270K PlusIntel vs AMDnext-gen CPUsPC HardwarePC upgradesprocessor performanceproductivity CPUssemiconductor industryTech Newsvalue performance
