Home Processors (CPU)
Intel Limited Edition i7 8086K Review
Better performance but not that much better
in Processors (CPU), Recent, Reviews
Intel Core i7-12700K Desktop Processor 12 (8P+4E) Cores up to 5.0 GHz Unlocked LGA1700 600...
Intel Core i7-12700K Desktop Processor 12 (8P+4E) Cores up to 5.0 GHz Unlocked  LGA1700 600 Series Chipset 125W
$259.00
39 new from $259.00
1 used from $279.99
as of March 23, 2026 8:13 pm
Intel Core i7-12700KF Desktop Processor 12 (8P+4E) Cores up to 5.0 GHz Unlocked LGA1700 600...
Intel Core i7-12700KF Desktop Processor 12 (8P+4E) Cores up to 5.0 GHz Unlocked  LGA1700 600 Series Chipset 125W
$209.99
33 new from $209.99
3 used from $249.99
Intel Core i9-11900K Desktop Processor 8 Cores up to 5.3 GHz Unlocked LGA1200 (Intel 500 Series &...
Intel Core i9-11900K Desktop Processor 8 Cores up to 5.3 GHz Unlocked LGA1200 (Intel 500 Series & Select 400 Series Chipset) 125W
$420.99
4 new from $420.99
3 used from $385.00
Last updated on March 23, 2026 8:13 pm
10. winRAR and x264 HD
  • 3. Test Bed
  • 4. Overclocking
  • 5. Adobe Performance
  • 6. Cinebench & Geekbench Results
  • 7. PCMark and POV-Ray Results
  • 8. AC:S & BF4
  • 9. Crysis 3, GTA V, Metro LL
  • 10. winRAR and x264 HD
  • 12. Closing Thoughts
winRAR Benchmark
Intel Limited Edition i7 8086K Review 24
x264 HD Benchmark
Intel Limited Edition i7 8086K Review 25
  • 3. Test Bed
  • 4. Overclocking
  • 8. AC:S & BF4
Page 10 of 12
Tags: 8086k Reviewi7 8086k vs i7 8700kI7-8086KIntelIntel 40thIntel i7intel Review
Gigabyte AORUS GTX 1070 Review
Intel Reclaiming Top Crown?
July 27, 2021
