Gigabyte AORUS GTX 1070 Review
Big card with big performance
in GPU, Recent, Reviews
GIGABYTE GeForce RTX 3060 Gaming OC 12G (REV2.0) Graphics Card, 3X WINDFORCE Fans, 12GB 192-bit...
GIGABYTE GeForce RTX 3060 Gaming OC 12G (REV2.0) Graphics Card, 3X WINDFORCE Fans, 12GB 192-bit GDDR6, GV-N3060GAMING OC-12GD Video Card
GIGABYTE Z590 AORUS ELITE AX (LGA 1200/ Intel Z590 ATX/ Triple M.2/ PCIe 4.0/ USB 3.2 Gen2X2...
GIGABYTE Z590 AORUS ELITE AX (LGA 1200/ Intel Z590 ATX/ Triple M.2/ PCIe 4.0/ USB 3.2 Gen2X2 Type-C/ Intel WIFI 6/ 2.5GbE LAN/ Gaming Motherboard)
GIGABYTE AORUS NVMe Gen4 M.2 1TB PCI-Express 4.0 Interface High Performance Gaming, Full Body...
GIGABYTE AORUS NVMe Gen4 M.2 1TB PCI-Express 4.0 Interface High Performance Gaming, Full Body Copper Heat Spreader, Toshiba 3D NAND, DDR Cache Buffer, SSD GP-ASM2NE6100TTTD
10. Temperature, Noise, and Power Analysis
  • 3. Closer look
  • 6.  AC: Syndicate, Batman: AK, BF 4
  • 12. Score Card and Summary
  • 13. Closing Thoughts
Gigabyte AORUS GTX 1070 Review 57
Sound Level Test Results
Gigabyte AORUS GTX 1070 Review 58
System Power Consumption
Gigabyte AORUS GTX 1070 Review 59
For an ACX based design the EVGA GeForce GTX 1070 FTW DT does have a lot going for it. Thanks to reference stock speeds it does – relatively speaking – sip power, is a very quiet video card, and is rather pretty. On the other hand at retail prices it may not glitter like gold for you. So take its rep with a grain of salt and see if its abilities do indeed line up with what you want it to be… and go from there.
  • 3. Closer look
Page 10 of 13
Tags: AorusGigabyteGigabyte AORUS GTX 1070Gigabyte AORUS GTX 1070 ReviewGTXGTX 1070gtx1070Nvidia
Crucial BX500 480GB Review 63
Lexar 3400x Cfast 2.0
July 21, 2015
Intel Innovation 2023
September 19, 2023
