EVGA CLC 240 Review
EVGA CLC 240 Review
EVGA CLC 240 Liquid CPU Cooler RGB
EVGA CLCx 240mm All-in-One LCD CPU Liquid Cooler, 2X 120mm PWM ARGB Fans, Intel, AMD, 5 YR...
EVGA CLCx 240mm All-in-One LCD CPU Liquid Cooler, 2X 120mm PWM ARGB Fans, Intel, AMD, 5 YR Warranty, 400-HY-CX24-V1
$155.58
9 new from $154.31
3 used from $143.72
as of October 2, 2026 5:12 am
EVGA CLC 120 CL11 Liquid Water CPU Cooler
5. Testing Methodology
  • 1. Moderate sized AIO with big value
  • 4. Installation & Issues
  • 6. Intel Testbed:
  • 7. AMD Testbed:
  • 8. Performance Results (stock fan configuration)
  • 9. Performance Results (Maximum # of Fans configuration)
While there are many, many ways of properly and efficiently testing CPU cooling solutions, not every method will offer useful information for all potential buyers. Some consumers care more about noise than sheer performance (aka ‘Silent PC’ enthusiasts). Others only care about performance and do not mind in the least if the cooler is as loud as a jet plane. Others still want to know how flexible a cooler is and how effective it will be at moderate – not silent – noise levels. Most though fall somewhere in the middle and want a good all-around design. Further complicating things is results on AMD systems do not necessarily translate to Intel-based testbeds (and vice versa) as the CPU is a different size and will come in direct contact with more/less of the CPU cooling solution’s heatsink.
To this end we are not just going to present you our readers with an overly simplified result and call it good enough. Instead we are going to do our best to provide you with as much data as possible so that you can make an informed decision based on what you consider to be important.
This different approach starts with testing on two testbeds and not just one. The first is an AMD AM4 Ryzen 1700X based system that is a good representation of what AMD users will experience. For Intel we have opted for a i7 8700K based system. Both are tested at stock and a moderately stressful overlock.
To round out our testing we have also included fan noise using stock number of fans included in the box, and at all successful rotational speed points. These results are taken using a professionally calibrated and NIST certified DT-805 sound meter that is placed 24 inches away from the cooler. We then spin up or down the fan on the cooling solution while the (Intel) CPU is idling.
  • 6. Intel Testbed:
  • 7. AMD Testbed:
Page 5 of 12
Tags: AIOAll in oneAMDBest Silent coolerCLCCLC 240CoolingCPU CoolerEVGAIntelMugen 5Mugen 5 ReviewNinja 5NoctuaReevenReeven E12RGBScytheSilent Coolerwater cooling
ASUS RoG STRIX GTX 1660Ti Review
