Crucial X8 2TB External SSD Review
Crucial X8 2TB Portable SSD – Up to 1050MB/s – USB 3.2 – External Solid State Drive, USB-C, USB-A...
Crucial X8 2TB Portable SSD – Up to 1050MB/s – USB 3.2 – External Solid State Drive, USB-C, USB-A – CT2000X8SSD9, Black
Crucial X6 2TB Portable SSD – Up to 800MB/s – USB 3.2 – External Solid State Drive, USB-C -...
Crucial X6 2TB Portable SSD – Up to 800MB/s – USB 3.2 – External Solid State Drive, USB-C - CT2000X6SSD9
Hard Case Compatible with SanDisk Extreme PRO/ for SanDisk 500GB 1TB 2TB 4TB Portable External...
Hard Case Compatible with SanDisk Extreme PRO/ for SanDisk 500GB 1TB 2TB 4TB Portable External SSD. Carrying Travel Holder for Crucial X8 External Solid State Drive (Box Only)
5. Synthetic Performance
  • 1. Upsetting the Status Quo Ante
  • 7. Score Card and Summary
ATTO Disk Benchmark
Crucial X8 2TB External SSD Review 18
Crucial X8 2TB External SSD Review 19
AS-SSD
Crucial X8 2TB External SSD Review 20
Crucial X8 2TB External SSD Review 21
Crystal DiskMark
Crucial X8 2TB External SSD Review 22
Crucial X8 2TB External SSD Review 23
Page 5 of 8
Tags: CrucialCrucial X8Crucial X8 2TB External SSDExternal SSDX8 Portable SSD
