Crucial T500 2TB Review
The Bigger and Better (Capacity) Option
Crucial T500 2TB Gen4 NVMe M.2 Internal Gaming SSD, Up to 7400MB/s, Laptop & Desktop Compatible +...
Crucial T500 2TB Gen4 NVMe M.2 Internal Gaming SSD, Up to 7400MB/s, Laptop & Desktop Compatible + 1mo Adobe CC All Apps - CT2000T500SSD8
System Boot Time
Crucial T500 2TB Review 34
Real World Data Transfers
No matter how good a synthetic benchmark like IOMeter is, it cannot really tell you how your hard drive will perform in “real world” situations. To this end we will be running timed data transfers to give you a general idea of how its performance relates to real life use. To help replicate worse case scenarios we will transfer a 30.00GB contiguous file, then a folder containing 1200 subfolders with a total 36,000 files varying in length from 200mb to 100kb (15.00 GB total).Testing will include transfer to and transferring from the devices, using MS RichCopy and logging the performance of the drive. Here is what we found.
Crucial T500 2TB Review 35
Crucial T500 2TB Review 36
Page 10 of 15
Tags: Advanced Storage SolutionsCacheComputer Componentscomputer hardwareComputer UpgradesControllersData StorageDurabilityHardwareHigh PerformanceM.2 SSDMainstream SSDNANDNext-Gen StoragePCIe 4.0PCIe 5.0performancePhison E25power efficiencyProduct ComparisonSSDSSD ReviewsStorage CapacityStorage DevicesStorage SpeedTech InnovationsTech ReviewsTechnologyTechnology TrendsValue for Money
Crucial T705 2TB Review
BenQ ScreenBar Review
CORSAIR VENGEANCE RGB PRO SL
January 21, 2021
