Home Ram
Crucial Pro OC DDR5-6400 32GB Review
Second Generation Goodness
in Ram, Reviews
Crucial Pro DDR5 RAM 32GB Kit (2x16GB), 6400MHz CL32, Overclocking Desktop Gaming Memory, Intel...
Crucial Pro DDR5 RAM 32GB Kit (2x16GB), 6400MHz CL32, Overclocking Desktop Gaming Memory, Intel XMP 3.0 & AMD Expo Compatible, Black - CP2K16G64C32U5B
3. DDR5 Primer P.1
  • 3. DDR5 Primer P.1
  • 4. DDR5 Primer P.2
  • 5. DDR5 Primer P.3
  • 6. Closer Look (Shipping Container)
  • 7. Closer Look (the kits themselves)
  • 8. Testing Methodology
  • 9. Adobe Performance
  • 10. Blender & Cinebench
  • 11. DaVinci & Handbrake
  • 12. POV-Ray & OpenSCAD
  • 13. SolidWorks & WinRAR
  • 14. AC:V, Borderlands 3, Metro Exodus
Crucial Pro OC DDR5-6400 32GB Review 5
A cynic would say that DDR5 was really created because the density of RAM is getting… well… denser. Yes, DDR4 allows for densities of up to 16Gbit (2GB) per IC. Yes, when DDR4 came about, that was a massive amount on a single IC. Those days are long in the past. These days, modern node sizes are so much smaller that this limitation means either wasting space on the wafer or making teeny-tiny ICs. Both solutions cost manufacturers money and reduce the profitonium included with every DDR4 RAM IC sale.
This is, arguably, why DDR5 allows for up to 64Gbit (8GB) ICs. Since a typical single-sided DIMM has room for eight ICs, and a double-sided one has room for sixteen ICs, this means, in theory, we could see a single stick of DDR5 with 128GB of capacity instead of the 32GB maximum with DDR4. Yes, for the average user who uses at most two 16GB sticks, this is a nothing-burger… as they will still want or need to populate two DIMMs. It’s only in the enterprise market that this is a major improvement (think of a single server with only eight DIMMs populated having 1TB of RAM). People will point to the fact that the number of pins hasn’t changed, the form factor really hasn’t changed (beyond a different key layout), and that it was only this increased density that brought about DDR5.
Crucial Pro OC DDR5-6400 32GB Review 6
We are cynical. We are jaded. We are not that cynical or that jaded… yet. DDR4 vs. DDR5 differences boil down to more, and are a bit more nuanced, than ‘density’. Yes, density needs to increase if we are to keep amount of RAM per core at reasonable levels in the face of 16/24 (and even more) mega-core-count CPUs going mainstream. There are however, major architectural differences that will pay dividends in the future, and some even pay dividends right now.
Crucial Pro OC DDR5-6400 32GB Review 7
For example, while yes the bus width per channel has not changed (much)… it is different. DDR4 uses a single 64-bit wide bus for each channel (i.e. with ‘dual’ Integrated Memory controllers, the bus is 128-bits wide, with ‘quad’ it is 256-bit wide memory bus etc. etc. etc.) and offers a burst speed of 64bytes per channel (i.e. a 8 burst length aka eight word lengths of data in one ‘burst’ aaka 64 data bits x 8). DDR5 uses two INDEPENDENT 32bit sub-channels for the bus (with each side of the DIMM getting its own sub-channel if both sides are populated) and offers a burst speed capable of squirting 64bytes (i.e. 32bits multiplied by a 16 burst length). Per sub-channel. 64 bytes is a big deal, as that is the typical CPU cache line size… meaning in a typical dual channel system DDR5 allows four full cache lines to be independently filled/emptied in a single go instead of just two. Which turns a dual channel into the equivalent of what a last gen quad channel system could do.
3. DDR5 Primer P.1
Page 3 of 16
Intel’s Holiday Hit List
Corsair 5000D Review
