in Reviews, Ram
7. Testing Methodology
  • 3. DDR5 Primer P.1
  • 4. DDR5 Primer P.2
  • 5. DDR5 Primer P.3
  • 6. Closer Look P.1
  • 8. Adobe Performance
  • 9. Blender & Cinebench
  • 10. DaVinci & Handbrake
  • 11. POV-Ray & OpenSCAD
  • 12. SolidWorks & WinRAR
The reasons to purchase a high-performance RAM kit are as varied as the consumers who purchase it. For some applications load time is the deciding factor in their purchasing decision. For others, it is Virtualized Operating System performance, or game load times. For others still, it is to shave a .1 of second off their synthetic test scores so as to climb ever higher in the online rankings that various sites host.
With such a wide variety of criteria, it incumbent upon us to use as wide and varied a list of testing protocols as possible. As such we have used a blend of synthetic and real-world benchmarks, as well as custom real-world game benchmarking.
The OS was a fresh clean install of Windows 11 with all the latest hotfixes, patches, and updates applied.
To show the performance differences we have tested at numerous frequency settings and timings. All tests were run 4 times and average results are represented.
For overclocking we do not overclock the CPU rather only the RAM is overclocked to show performance gains that the RAM will net consumers. Unless otherwise noted, to ensure that any overclock we do obtain is realistic we also limit voltage to – at most – 1.45volts (DDR4) or 1.4volts (DDR5). Anything above this borders on danger to the RAM and will noticeably reduce the longevity of the RAM ICs.
Intel Test System
Processor: Intel Core Ultra 9 285K
Memory: Review Kit(s)
Motherboard: MSI MAG Z90 Tomahawk WIFI
Cooling: Arctic Liquid Freezer III 420 w/ 3 fans
SSD: 1x Crucial MX500 1TB
Power Supply: Corsair AX860i
Video Cards: ASUS TUF GeForce RTX 3090Ti
OS: Windows 11
AMD Test System
Processor: : AMD Ryzen 9 9950X
Motherboard: MSI MPG X870E CARBON WIFI
OS: Windows 11
Special thanks to Artic for their support and for providing the Arctic Liquid Freezer III 420 A-RGB White edition – it is a beast and makes things so much easier.
Page 7 of 15
Asus ZenFone 2
Asus ZenFone 2
November 23, 2015
