Crucial P310 2TB Review
Can good things come in (ultra) small packages?
in Storage, Reviews
Crucial New 2024 P310 2TB PCIe Gen4 2230 NVMe M.2 SSD - Up to 7,100 MB/s - Uplevel Your Console -...
Crucial New 2024 P310 2TB PCIe Gen4 2230 NVMe M.2 SSD - Up to 7,100 MB/s - Uplevel Your Console - Internal Solid State Drive (PC) - CT2000P310SSD2​​
6. Sequential Performance
Read Bandwidth
Crucial P310 2TB Review 29
Write Performance
Crucial P310 2TB Review 30
Page 6 of 15
Tags: computing devicesCrucial T500DRAM-less SSDform-factor tradegaming driveshigh read/write speedsIntel NUClow-power storageM.2 2230mini-PCsoverkill performancePCIe NVMe SSDportable PCQLC NANDRAID setupsmall form-factorSSDSteam Deckstorage performance
