Crucial P310 2TB Review
Can good things come in (ultra) small packages?
in Storage, Reviews
Crucial New 2024 P310 2TB PCIe Gen4 2230 NVMe M.2 SSD - Up to 7,100 MB/s - Uplevel Your Console -...
Crucial New 2024 P310 2TB PCIe Gen4 2230 NVMe M.2 SSD - Up to 7,100 MB/s - Uplevel Your Console - Internal Solid State Drive (PC) - CT2000P310SSD2​​
Crucial P310 2TB Review 6
Crucial P310 2TB Review 7
As time went by MLC was further supplanted by TLC (Tri-Level Cell) NAND which can store three bits of data per cell. In TLC NAND there are not two, not four, but eight voltage states (for comparison’s sake to hit 4 bits per cell, QLC NAND requires sixteen voltage points). This in turn increases the necessary precision in properly writing and reading a given state of a NAND cell. It also significantly decreases how long a TLC NAND cell will hold this more precise voltage state. This increased precision plays a large role in why TLC NAND is ‘slower’ at write operations than MLC (which is in turn slower than SLC)… and why QLC (and its sixteen votlage points) is slower still.
Crucial P310 2TB Review 8
Crucial P310 2TB Review 9
Crucial P310 2TB Review 10
Crucial P310 2TB Review 11
Crucial P310 2TB Review 12
Crucial P310 2TB Review 13
Crucial P310 2TB Review 14
Page 3 of 15
Tags: computing devicesCrucial T500DRAM-less SSDform-factor tradegaming driveshigh read/write speedsIntel NUClow-power storageM.2 2230mini-PCsoverkill performancePCIe NVMe SSDportable PCQLC NANDRAID setupsmall form-factorSSDSteam Deckstorage performance
