Back in Black and On the Attack
Cooler Master Hyper 212 Halo Black CPU Air Cooler, MF120 Halo² Fan, Dual Loop ARGB, Aluminum Top...
Cooler Master Hyper 212 Halo Black CPU Air Cooler, MF120 Halo² Fan, Dual Loop ARGB, Aluminum Top Cover, 4 Copper Heat Pipes, 154mm (H) for AMD Ryzen AM5/AM4, Intel LGA1700/1200 (RR-S4KK-20PA-R1)
Cooler Master Hyper 212 Halo White CPU Cooler - 120mm Fan | Support AMD & Intel CPU Socket AM5,...
Cooler Master Hyper 212 Halo White CPU Cooler - 120mm Fan | Support AMD & Intel CPU Socket AM5, AM4 / LGA 1700, 1200, 1151, 1150| PWM Case Fans | 51.88 CFM Airflow | 4 Heat Pipes | Gen 2 ARGB
5. Testing Methodology
  • 4. Installation and Issues
This different approach starts with testing on two testbeds and not just one. The first is an Intel 12th generation Core i9-12900K CPU. This CPU’s thermal characteristics make it a good representation of “worst case scenario’ for what most users will experience. For AMD fans, we have gone old school with a hot running Zen 1 processor. A processor that just plumb doesn’t like to run cool.
Intel Testbed:
Processor: Intel Core i9-12900K
Memory: Kingston Fury DDR5-5600
Cooling: Various
Power Supply: Corsair AX860i
Monitor: Dell U2714H
OS: Windows 11 Professional
AMD Testbed:
Processor: AMD Ryzen 7 1700
Motherboard: ASUS RoG STRIX X370-F Gaming
Cooling: Various
Page 5 of 9
Tags: air coolerCooler masterCooler Master Hyper 212 Halo Blackcpu cooling
TerraMaster Newly Released 10GbE NAS T9-450 and T12-450
