Silicon Power UD70 2TB Review
in Storage, Reviews
Silicon Power 2TB UD90 NVMe 4.0 Gen4 PCIe M.2 SSD R/W up to 5,000/4,800 MB/s (SP02KGBP44UD9005)
Silicon Power 2TB NVMe M.2 PCIe Gen3x4 2280 SSD Solid State Drive (SP002TBP34A60M28)
9. Boot time and Data Transfer
  • 1. Large capacity, massive value
  • 5. Sequential Performance
  • 6. ATTO Disk Benchmark
  • 8. IOMeter
  • 10. Adobe & VMWare
  • 11. Game Load Time
  • 13. Score Card and Summary
  • 14. Closing Statement
System Boot Time
Silicon Power UD70 2TB Review 23
Real World Data Transfers
No matter how good a synthetic benchmark like IOMeter is, it cannot really tell you how your hard drive will perform in “real world” situations. To this end we will be running timed data transfers to give you a general idea of how its performance relates to real life use. To help replicate worse case scenarios we will transfer a 100.00GB contiguous file, then a folder containing 1200 subfolders with a total 36,000 files varying in length from 200mb to 100kb (30.00 GB total).
Silicon Power UD70 2TB Review 24
Silicon Power UD70 2TB Review 25
  • 8. IOMeter
Page 9 of 14
Tags: Silicon PowerSilicon Power UD70 2TBUD70UD70 2TB
MSI Presents SUPRIM X 3090 3080 3070 Graphics Cards
