Silicon Power UD70 2TB Review
in Storage, Reviews
Silicon Power 2TB UD90 NVMe 4.0 Gen4 PCIe M.2 SSD R/W up to 5,000/4,800 MB/s (SP02KGBP44UD9005)
Silicon Power 2TB NVMe M.2 PCIe Gen3x4 2280 SSD Solid State Drive (SP002TBP34A60M28)
5. Sequential Performance
  • 1. Large capacity, massive value
  • 5. Sequential Performance
  • 6. ATTO Disk Benchmark
  • 8. IOMeter
  • 10. Adobe & VMWare
  • 11. Game Load Time
  • 13. Score Card and Summary
  • 14. Closing Statement
Read Bandwidth
Silicon Power UD70 2TB Review 14
Write Performance
Silicon Power UD70 2TB Review 15
  • 8. IOMeter
Page 5 of 14
Tags: Silicon PowerSilicon Power UD70 2TBUD70UD70 2TB
MSI Presents SUPRIM X 3090 3080 3070 Graphics Cards
