Silicon Power 2TB USB-C USB 3.0 Rugged Portable External Hard Drive Armor A66, Military-Grade...
Silicon Power 2TB USB-C USB 3.0 Rugged Portable External Hard Drive Armor A66, Military-Grade Shockproof/Water-Resistant for PC, Mac and iPad Pro, Blue
Silicon Power External HDD Armor A66 2To
5. Synthetic Performance
  • 1. Ruggedization Done (mostly) Right
  • 7. Score Card and Summary
ATTO Disk Benchmark
Silicon Power Armor A66 Review 21
Silicon Power Armor A66 Review 22
AS-SSD
Silicon Power Armor A66 Review 23
Silicon Power Armor A66 Review 24
Crystal DiskMark
Silicon Power Armor A66 Review 25
Silicon Power Armor A66 Review 26
Page 5 of 8
Tags: Hard DriveHDDportableruggedsilicon power a66
MSI Clutch GM41 Review
Cooler Master MM730 Review
Lexar 3400x Cfast 2.0
July 21, 2015
Intel Innovation 2023
September 19, 2023
