Silicon Power A55 M.2 1TB
SATA and M.2?
7. Crystal Diskmark & AS-SSD
  • 5. Sequential Performance
  • 6. ATTO Disk Benchmark
  • 8. IOMeter
  • 10. Adobe & VMWare
  • 11. Game Load Time
  • 13. Score Card and Summary
  • 14. Closing Statement
Crystal DiskMark
Silicon Power A55 M.2 1TB 18
Silicon Power A55 M.2 1TB 19
AS-SSD
Silicon Power A55 M.2 1TB 20
Silicon Power A55 M.2 1TB 21
  • 8. IOMeter
Page 7 of 14
