in Reviews
12. Boot time and Data Transfer
  • 6. Closer Look p.1
  • 7. Closer Look p.2
  • 8. Sequential Performance
  • 9. ATTO Disk Benchmark
  • 11. IOMeter
  • 13. Adobe & VMWare
  • 14. Game Load Time
  • 16. Score Card and Summary
  • 17. Closing Statement
System Boot Time
Seagate Exos X24 Review 40
Real World Data Transfers
Seagate Exos X24 Review 41
Seagate Exos X24 Review 42
  • 11. IOMeter
Page 12 of 17
January 18, 2018
