Seagate Exos X18 Review
7. Sequential Performance
  • 2. Specs
  • 5. Closer Look
Read Bandwidth
Seagate Exos X18 Review 27
Write Performance
Seagate Exos X18 Review 28
  • 2. Specs
  • 5. Closer Look
Page 7 of 16
Tags: ExosSeagate Exos X18X18
May 9, 2014
