Scythe Ninja 5 Review
The silent assassin that may be too silent
in Reviews, Recent, Unboxing, Video Reviews
Scythe Ninja 5 CPU Air Cooler, 120mm Single Tower, Intel LGA1151, AMD AM4, Dual Quiet Fans, Black...
Scythe Ninja 5 CPU Air Cooler, 120mm Single Tower, Intel LGA1151, AMD AM4, Dual Quiet Fans, Black Top Cover
Ninja AG301 Foodi 5-in-1 Indoor Grill with Air Fry, Roast, Bake & Dehydrate, Black/Silver
Scythe Mugen 5 Rev.C CPU Air Cooler, 120mm Single Tower, Intel LGA1700, LGA1151, AMD AM5/AM4/Ryzen
5. Ninja 5: Testing Methodology
  • 3. Ninja 5: Closer Look
  • 4. Installation Issues
  • 5. Ninja 5: Testing Methodology
  • 9. Score Card and Summary
  • 10. Ninja 5: Closing Statement
While there are many, many ways of properly and efficiently testing CPU cooling solutions not every method will offer useful information for all potential buyers. Some consumers care more about noise than sheer performance (aka ‘Silent PC’ enthusiasts). Others only care about performance and do not mind in the least if the cooler is as loud as a jet plane. Others still want to know how flexible a cooler is and how effective it will be at moderate – not silent – noise levels. Most though fall somewhere in the middle and want a good all-round design. Further complicating things is results on AMD systems do not necessarily translate to Intel based testbeds (and vice versa) as the CPU is a different size and will come in direct contact with more/less of the CPU cooling solution’s heatsink.
To this end we are not just going to present you our readers with an overly simplified result and call it good enough. Instead we are going to do our best to provide you with as much data as possible so that you can make an informed decision based on what you consider to be important.
This different approach starts with testing on two testbeds and not just one. The first is an AMD AM4 Ryzen 1700X based system that is a good representation of what AMD users will experience. For Intel we have opted for a i7 8700K based system. Both are tested at stock and a moderately stressful overlock.
The included results are the average for 20 minutes of stress testing using Aida64 and its built in stress testing with logging feature enabled (as found under File / Preferences / Hardware Monitoring / Logging). In cases where ‘maximum’ fan speed falls between two chart points we will take a rounding up approach and place the max numbers under the higher fan speed point.
To round out our testing we have also included fan noise using stock number of fans included in the box, and at all successful rotational speed points. These results are taken using a professionally calibrated and NIST certified DT-805 sound meter that is placed 24 inches away from the cooler. We then spin up or down the fan on the cooling solution while the (Intel) CPU is idling.
Intel Testbed:
Processor: Intel 8086K
Memory: Ballistix Sport AR DDR4-3000
Motherboard: ASUS TUF-Z370 Pro Gaming
Cooling: Noctua NH-D15
Power Supply: Corsair AX860i
Monitor: Dell U2714H
OS: Windows 10 Professional
AMD Testbed:
Processor: AMD Ryzen 1700X
Motherboard: ASUS ROG Strix X370-F GAMING
Cooling: various
Scythe Ninja 5 Review 30
Page 5 of 10
Previous 12345678910 Next
Tags: AMDBest Silent coolerCoolingCPU CoolerIntelMugen 5Mugen 5 ReviewNinja 5NoctuaRGBScytheSilent Cooler
Zotac Mek Mini – Small Doesn’t Mean Less
Zotac Mek Mini - Small Doesn't Mean Less
