PNY GTX 780 Ti XLR8 Review
in GPU, Reviews
PNY 780 Ti Cover
PNY GeForce GTX 1080 Ti 11GB Blower Design (VCGGTX1080T11PB-CG2) Graphic Cards
PNY XLR8 CS3040 2TB M.2 NVMe Gen4 x4 Internal Solid State Drive (SSD) - M280CS3040-2TB-RB
PNY XLR8 Gaming 16GB (2x8GB) DDR4 DRAM 3200MHz (PC4-25600) CL16 1.35V Dual Channel Desktop (DIMM)...
PNY XLR8 Gaming 16GB (2x8GB) DDR4 DRAM 3200MHz (PC4-25600) CL16 1.35V Dual Channel Desktop (DIMM) Memory Kit – MD16GK2D4320016AXR
14. Temperature, Noise, and Power Analysis
  • 3. A Closer Look at the PNY GeForce GTX 780Ti XLR8
  • 5. Sleeping Dogs Gaming Benchmark
  • 6. Metro: Last Light Gaming Benchmark
  • 7. BioShock Infinite Gaming Benchmark
  • 8. Tomb Raider Gaming Benchmark
  • 9. Batman Arkham Origins Gaming Benchmark
  • 10. Battlefield 4 Gaming Benchmark
  • 11. Assassins Creed: Black Flag Gaming Benchmark
  • 12. Call of Duty: Ghosts Gaming Benchmark
  • 13. Crysis 3 Gaming Benchmark
  • 15. Overclocking
  • 16. Performance Summary & TL;DR
  • 17. Score Card
  • 18. Closing Statement
PNY GTX 780 Ti XLR8 Review 33
Sound Level Test Results
While everyone “hears” noise differently there is one easy way to remove all subjectivness and easily compare different fans: use a sound level meter. This way you can easily compare the various fans noise envelopes without us colouring the results and see what fans fit within your personal comfort level. Of course, we will endeavour to try and explain the various results – which are taken at a 15 inch distance from the GPU’s fan(s) – to help you gain an even better understanding of how loud a cooler’s stock fan is, but even if you discount our personal opinions, the fact remains numbers don’t lie.
For Idle tests, we let the system idle at the Windows 7 desktop for 25 minutes and recorded the peak dB.
PNY GTX 780 Ti XLR8 Review 34
While the stock NIVIDIA cooler may not exactly be as aggressive looking as some custom cooling solutions it does get the job done. Just as importantly not only does it keep the fully enabled GK110 core running at a rather reasonable temperature levels it does so without being as loud as a vacuum cleaner. In fact, it is rather mild compared to some previous generation designs and certainly puts AMD’s stock cooler to shame.
System Power Consumption
To obtain accurate results we have connected the system to a Power Angle power meter that has in turn been attached to a 1500watt UPS. This ensures only 120volt power is supplied to the PSU and removes an varaiences that could potential crop up because of brownouts and power spikes.
PNY GTX 780 Ti XLR8 Review 35
Even with a full 25% more cores, the PNY GeForce GTX 780Ti XLR8 is not what we would call a power hog by any stretch of the imagination. Simply put, in return for approximately 40 watt increase in power consumption consumers get to take advantage of all that extra horsepower. That is a trade-off many – including ourselves – would be more than willing to make. This goes double when you consider that while idling the differences between a stock 780, a GTX Titan and the PNY GeForce GTX 780Ti XLR8 is only a couple watts and certainly not enough to worry about.
  • 15. Overclocking
  • 17. Score Card
Page 14 of 18
Nvidia’s Phil Scholz killed in Train Accident
Nvidia's Phil Scholz killed in Train Accident
