PNY GeForce GTX 770 4GB XLR8 OC2
in GPU, Reviews
PNY GeForce GTX 770 4GB XLR8 OC2 1
PNY NVIDIA GeForce GTX 1050 Ti 4GB Graphics Card (VCGGTX1050T4PB)
PNY GeForce GTX 1650 Super 4GB Single Fan Graphics Card VCG16504SSFPPB
PNY GeForce GTX 1650 4GB GDDR6 Dual Fan Graphics Card
$355.00
as of March 31, 2026 2:43 am
Last updated on March 31, 2026 2:43 am
16. Overclocking
  • 3. A Closer Look at the PNY GeForce GTX 770 XLR8 OC2
  • 5. Synthetic Game Benchmarks
  • 6. Metro: Last Light Gaming Benchmark
  • 7. BioShock Infinite Gaming Benchmark
  • 8. Tomb Raider Gaming Benchmark
  • 9. Batman Arkham Origins Gaming Benchmark
  • 10. Battlefield 4 Gaming Benchmark
  • 11. Assassins Creed: Black Flag Gaming Benchmark
  • 12. Call of Duty: Ghosts Gaming Benchmark
  • 13. Crysis 3 Gaming Benchmark
  • 14. Sound Level Test Results
  • 15. System Power Consumption
  • 16. Overclocking
  • 17. Score Card,  Summary and TL;DR
  • 18. Closing Statement
Overclocking
To discover our PNY GeForce GTX 770 XLR8 OC2 sample’s overclocking abilities we used EVGA’s Precision X software and began raising power and thermal thresholds to the maximum allowed and then increased the voltage also to the maximum permitted. Then using Unigine’s Valley benchmark we began stability testing.
It came as almost no surprise that there was not much room left for further overclocking over what PNY has already applied to this heavily overclocked card. On the positive side, even highly overclocked 770s will still run into performance issues long before VRam really becomes an issue, but the extra 2GB certainly did not hinder performance all that much. If you are interested in manual overclocking the higher density DDR5 RAM’s headroom will be lower than the DDR5 found on the 2GB model, but it really was the lack of voltage headroom on the GK104 that held things back, rather than the VRAM per say.
With that being said we were able to boost performance further than we thought on both the RAM and GK104. Thanks to the excellent factory cooler PNY has used, we were able to reach a base clock of 1,210MHz -or an additional 60Mhz over the factory overclock. This is an additional 5.2% increase on the already impressive factory overclocking settings and a whopping 164Mhz increased over a reference GeForce GTX 770’s levels. Put another way, when manually overclocked this GK104 runs 15.7% faster than a GK104 found in a reference GeForce 770. On the memory side of the equation we were able to boost the memory to an effective 7448Mhz, which is a 6.2 percent improvement over the card’s default 7012Mhz – and excellent 448MHz boost over a reference 770’s settings.
PNY GeForce GTX 770 4GB XLR8 OC2 42
PNY GeForce GTX 770 4GB XLR8 OC2 43
With only a minor-to-moderate increase in speeds the only minor increase in real world performance was expected. With that being said the improvement is tangible and does add frames per second to the bottom line. More impressive still, this GeForce GTX 770 was able to claw within striking distance of a stock 780 on the all-important minimum frame rates! Seventy dollars for a single additional FPS definitely doesn’t sound like all that great a deal to us.
16. Overclocking
  • 16. Overclocking
Page 16 of 18
Free Copy of Dead Space
12th Gen Intel Core HX Processors
May 10, 2022
Mad Catz F.R.E.Q. 3
Mad Catz F.R.E.Q. 3
January 11, 2016
