Orico USB to M2 adapters Review
Small form-factor, big performance
ORICO M.2 SATA SSD External Enclosure Tool-Free USB 3.1 Type-C Adapter, Support NGFF(SATA Based)...
ORICO M.2 SATA SSD External Enclosure Tool-Free USB 3.1 Type-C Adapter, Support NGFF(SATA Based) M.2 2280 2260 2242 2230 SSD Enclosure Adapter-(TCM2F, Black)
ORICO NVME M.2 to Type-C USB3.1 Gen2 10Gbps Transparent External Solid State Drive Adapter...
ORICO NVME M.2 to Type-C USB3.1 Gen2 10Gbps Transparent External Solid State Drive Adapter Enclosure for 2280 2260 2242 2230 PCI-E M2 M-Key SSD, USB Type C Converter Case (TCM2-Blue)
ORICO M.2 SSD Enclosure 6Gbps M.2 SATA to USB-C Adapter USB3.1 Gen1 for B-Key/B+M Key SSD...
ORICO M.2 SSD Enclosure 6Gbps M.2 SATA to USB-C Adapter USB3.1 Gen1 for B-Key/B+M Key SSD (2230/2242/2260/2280) , M2 External NGFF SATA SSD Case Reader with UASP, Trim, Smart, SSD Max 4TB-MM2-Green
6. Real World Performance
  • 1. Small form-factor, big performance
  • 7. Score Card & Summary
Many novices do not understand the importance of write performance and how great an impact it can have on real world performance. To show exactly what this new series can do we have also created a test that will do precisely that by the simplest expedient of copying either large or small files to and from the device. This way you the reader can see how it will react when tasked with two very common scenarios.
This test was done 4 times per card and the averages for each are listed below.
Orico USB to M2 adapters Review 29
Orico USB to M2 adapters Review 30
Page 6 of 8
Tags: NVMEnvme to usboricopcmrportable nvmereviewSeagateSilicon PowerSSDstorageusb 3.1 to nvmeWD
Crucial MX300 1050GB
November 21, 2016
Acronis True Image 2019 Review
