Orico USB to M2 adapters Review
Small form-factor, big performance
ORICO M.2 SATA SSD External Enclosure Tool-Free USB 3.1 Type-C Adapter, Support NGFF(SATA Based)...
ORICO M.2 SATA SSD External Enclosure Tool-Free USB 3.1 Type-C Adapter, Support NGFF(SATA Based) M.2 2280 2260 2242 2230 SSD Enclosure Adapter-(TCM2F, Black)
ORICO NVME M.2 to Type-C USB3.1 Gen2 10Gbps Transparent External Solid State Drive Adapter...
ORICO NVME M.2 to Type-C USB3.1 Gen2 10Gbps Transparent External Solid State Drive Adapter Enclosure for 2280 2260 2242 2230 PCI-E M2 M-Key SSD, USB Type C Converter Case (TCM2-Blue)
ORICO M.2 SSD Enclosure 6Gbps M.2 SATA to USB-C Adapter USB3.1 Gen1 for B-Key/B+M Key SSD...
ORICO M.2 SSD Enclosure 6Gbps M.2 SATA to USB-C Adapter USB3.1 Gen1 for B-Key/B+M Key SSD (2230/2242/2260/2280) , M2 External NGFF SATA SSD Case Reader with UASP, Trim, Smart, SSD Max 4TB-MM2-Green
5. Synthetic Performance
  • 1. Small form-factor, big performance
  • 7. Score Card & Summary
ATTO Disk Benchmark
Orico USB to M2 adapters Review 23
Orico USB to M2 adapters Review 24
AS-SSD
Orico USB to M2 adapters Review 25
Orico USB to M2 adapters Review 26
Crystal DiskMark
Orico USB to M2 adapters Review 27
Orico USB to M2 adapters Review 28
Page 5 of 8
Tags: NVMEnvme to usboricopcmrportable nvmereviewSeagateSilicon PowerSSDstorageusb 3.1 to nvmeWD
May 9, 2014
