Nixeus NX-EDG34S Review
The Epitome of 21:9 Value
in Reviews, Accessories
$29.99
$50.00
9 new from $29.99
as of March 21, 2026 8:52 pm
$194.00
6 new from $194.00
8 used from $119.99
Last updated on March 21, 2026 8:52 pm
8. Manual Color correction
  • 8. Manual Color correction
  • 9. Score Card and Summary
  • 10. Closing Statement
Nixeus monitors have always come with On Screen Displays that are best described as decent bordering on good. They make lack the in-depth 6-axis adjustments of some other manufactures but the combination of physical buttons with a consistent and well thought out OSD makes for a very good combination. One where you can easily ‘get the job done’ without too much hassle.
Since this monitor is not factory calibrated you may want to either invest in a colorimeter (Spyder or i1Display Pro) or manually adjust the colors. Either option will net you good results. Of course… a i1Display Por will net you perfection but you will be dropping nearly 3 bills (USD) on it. For a single usage event ‘good enough’ may indeed be good enough.
Nixeus NX-EDG34S Review 37
Nixeus NX-EDG34S Review 38
For our sample, and a place to start not finish… as every EDG 34S will vary, we started by lowering all three primary colors by 4. We then raised Red by 1, raise blue back up by 4, and green by 2 points in the OSD. This with a light touch to the gamma levels netted us results that ranged from 99 to 101 on Red, Green and Blue – with an average of a perfect 100 – depending on precisely where we measured the colors on the screen. With a bit of time, around twenty to thirty minutes, and patience you will easily dial in your EDG 34S’ colors well enough that only professionals will notice a slight variance. Once again if you want perfection buy a colorimeter. Everyone else will consider the small-time investment a better deal than investing in overkill colorimeters.
Page 8 of 10
Previous 12345678910 Next
LaCie Rugged SSD 1TB Review
Intel Unveils 14th Gen Processors at CES 2024
January 8, 2024
Intel Panther Lake
Intel Panther Lake
October 9, 2025
