Nixeus NX-EDG274K Review
144Hz 4K Goodness
in Reviews, Accessories, Monitors
Logitech G502 X PLUS LIGHTSPEED Wireless Optical mouse with LIGHTFORCE hybrid switches, LIGHTSYNC...
Logitech G502 X PLUS LIGHTSPEED Wireless Optical mouse with LIGHTFORCE hybrid switches, LIGHTSYNC RGB, HERO 25K gaming sensor, compatible with PC - macOS/Windows - Black
Logitech G PRO X SUPERLIGHT Wireless Gaming Mouse, Ultra-Lightweight, HERO 25K Sensor, 25,600...
Logitech G PRO X SUPERLIGHT Wireless Gaming Mouse, Ultra-Lightweight, HERO 25K Sensor, 25,600 DPI, 5 Programmable Buttons, Long Battery Life, Compatible with PC / Mac - Black
9. Manual Color correction
  • 9. Manual Color correction
  • 10. Score Card and Summary
  • 11. Closing Statement
We would love to have been able to step you through exactly what you need to do get your NX-ED274K color correct… or at least in the right ballpark. Unfortunately, we won the panel lottery and ours came so close to perfect out of the box that our colorimeter made only a minor difference after creating a custom ICC profile. Yes, this is one of the few times where we are unhappy to have won the panel lottery.
Nixeus NX-EDG274K Review 45
What we can do is step you through the basic process on what you will need to do if you your monitor is not ‘perfect’ out of the box. First turn of HDR. With HDR on… all manual color correction abilities are turned off. So if you really want faux HDR and accurate colors… buy a colorimeter… or better still drop a couple grand on a HDR1000, 10-bit monitor.
Nixeus NX-EDG274K Review 46
Then in the ‘Advance’ section turn DSC off (as for ease of correction it is best to not have a compressed stream hitting your monitor… you can turn it back on later if you want). Then keep clicking until you scroll to the second page and make sure FreeSync is on. If you do not have a DP1.4 capable video card change the DP setting to a lower standard as well.
Nixeus NX-EDG274K Review 47
Next, go to the ‘Color’ subsection, set gamma to 2.2. Then color temp to ‘user’… not 6500K. Then make sure color format is set to R/G/B and PCM is ‘native’. In ‘Color Temp. User’ subsection you have access to R/G/B color corrections. Adjust as you see fit.
For light level output we would adjust panel and brightness settings so that they are fairly close together but the panel backlight setting is higher than brightness. For some that want 120 you will be turning these down to the high teen to low 20 range. For others it will be higher. It really depends on your environment and what looks ‘right’ to you. That’s about it.
Page 9 of 11
Previous 1234567891011 Next
Tags: 1080p gaming244hz gamingASUS VG279QMGaminghigh refresh rateNixeusNixeus NX-EDG274KNX-EDG274KpcmrTUFTUF Gaming VG279QM
January 5, 2017
