Nixeus NX-EDG274K Review
144Hz 4K Goodness
in Reviews, Accessories, Monitors
Logitech G502 X PLUS LIGHTSPEED Wireless Optical mouse with LIGHTFORCE hybrid switches, LIGHTSYNC...
Logitech G502 X PLUS LIGHTSPEED Wireless Optical mouse with LIGHTFORCE hybrid switches, LIGHTSYNC RGB, HERO 25K gaming sensor, compatible with PC - macOS/Windows - Black
Logitech G PRO X SUPERLIGHT Wireless Gaming Mouse, Ultra-Lightweight, HERO 25K Sensor, 25,600...
Logitech G PRO X SUPERLIGHT Wireless Gaming Mouse, Ultra-Lightweight, HERO 25K Sensor, 25,600 DPI, 5 Programmable Buttons, Long Battery Life, Compatible with PC / Mac - Black
4. Panel Performance (Uniformity and Response rate)
  • 9. Manual Color correction
  • 10. Score Card and Summary
  • 11. Closing Statement
Review note:
As is our standard operating procedure all testing was carried out at 120 cd/m2 unless otherwise noted.
Uniformity
Optimally a panel should show perfect uniformity across the entirety of its screen real-estate. We have yet to see one exhibit perfection. Instead we consider 15% (i.e. plus or minus 7.5 percent) or lower to be extremely good, and 15 to 24 percent to be ‘good enough’. Anything above this does not meet our absolute minimum standards and will be considered a failure. For this test we do not use 120 nit setting and instead set it to 350’ish output – or as close as to that brightness levels as possible. For testing and recording we used DisplayCAL.
Nixeus NX-EDG274K Review 25
Like most IPS panel-based monitors there is going to be a bit more light leakage than with say VA based models. ‘IPS Glow’ is real and is just part of the deal when you buy nearly any moderately priced IPS monitor. With that said, the EDG274K had very little glow and the uniformity was indeed above average. The absolute highest deviation we observed was a bit over 9 percent and the panels entire deviation was all one direction with no ‘bright spots’. This combination is more that good enough, and most people will be more than happy with it.
Response Rate
Even though a panel is rated in both milliseconds (response rate) and Hz (frame rate) the reality is this will give at best only a rough picture of a panels true abilities. Things such as ghosting, or worse still reverse ghosting, where there is more than one image displayed at a time will negatively impact enjoyment and immersion in fast paced scenarios. This is why we use a combination of Blur Busters online Ghosting test and a high-speed camera to capture real world response rate using the ‘out of the box’ settings. To give as clear a picture, pardon the pun, as possible we have also included the best and worst results observed over 2,000 images taken.
Please note, in this test images move from Left to Right on the screen.
Nixeus NX-EDG274K Review 26
Nixeus NX-EDG274K Review 27
Page 4 of 11
Previous 1234567891011 Next
Tags: 1080p gaming244hz gamingASUS VG279QMGaminghigh refresh rateNixeusNixeus NX-EDG274KNX-EDG274KpcmrTUFTUF Gaming VG279QM
September 3, 2024
CORSAIR VENGEANCE RGB PRO SL
January 21, 2021
