Nixeus EDG27240X Review
in Reviews, Monitors
5. Panel Performance (Uniformity and Response rate)
  • 10. Manual Color correction
  • 12. Conclusion
Review note:
As is our standard operating procedure all testing was carried out at 120 cd/m2 unless otherwise noted.
Uniformity:
Optimally a panel should show perfect uniformity across the entirety of its screen real-estate. We have yet to see one exhibit perfection. Instead we consider 15% (i.e. plus or minus 7.5 percent) or lower to be extremely good, and 15 to 24 percent to be ‘good enough’. Anything above this does not meet our absolute minimum standards and will be considered a failure. For this test we do not use 120 nit setting and instead set it to about its 50 percent luminance rated output. For testing and recording we used DisplayCAL.
Nixeus EDG27240X Review 24
Like most IPS / “AHVA” panel-based monitors there is almost always going to be some light leakage. It is just the nature of the IPS beast and something you have to be willing to live with when buying an IPS based monitor. With that said, the EDG27240X is decent in this department with about a 11 percent variance. Not perfect, but well above ‘good enough’ for most buyers.
Response Rate:
Even though a panel is rated in both milliseconds (response rate) and Hz (frame rate) the reality is this will give at best only a rough picture of a panels true abilities. Things such as ghosting, or worse still reverse ghosting, where there is more than one image displayed at a time will negatively impact enjoyment and immersion in fast paced scenarios. This is why we use a combination of Blur Busters online Ghosting test and a high-speed camera to capture real world response rate using the ‘out of the box’ settings. To give as clear a picture, pardon the pun, as possible we have also included the best and worst results observed over 2,000 images taken.
Please note, in this test images move from Left to Right on the screen.
Nixeus EDG27240X Review 25
Nixeus EDG27240X Review 26
  • 12. Conclusion
Page 5 of 12
Alienware M15 R7 Review
Intel Unveils Next-Gen vPro Platform at MWC 2024
February 27, 2024
