Home Recent
in Recent, GPU, Reviews
MSI Gaming GeForce RTX 4080 16GB GDRR6X 384-Bit HDMI/DP Nvlink Tri-Frozr 3 Ada Lovelace...
MSI Gaming GeForce RTX 4080 16GB GDRR6X 384-Bit HDMI/DP Nvlink Tri-Frozr 3 Ada Lovelace Architecture Graphics Card (Gaming X Trio)
MSI Gaming GeForce RTX 4090 24GB GDRR6X 384-Bit HDMI/DP Nvlink Tri-Frozr 3 Ada Lovelace...
MSI Gaming GeForce RTX 4090 24GB GDRR6X 384-Bit HDMI/DP Nvlink Tri-Frozr 3 Ada Lovelace Architecture OC Graphics Card (RTX 4090 Gaming X Trio 24G)
MSI Gaming GeForce RTX 3070 Ti 8GB GDRR6X 256-Bit HDMI/DP Nvlink Torx Fan 3 Ampere Architecture...
MSI Gaming GeForce RTX 3070 Ti 8GB GDRR6X 256-Bit HDMI/DP Nvlink Torx Fan 3 Ampere Architecture OC Graphics Card (RTX 3070 Ti Gaming X Trio 8G)
15. Temperature, Noise, and Power Analysis
  • 1. Premium 1440P gaming goodness
  • 5. Overclocking Results
  • 6. AC: Origins, AC: Odyssey
  • 7. Battlefield 1, Battlefield 5
  • 8. CoD: IW, CoD: WW2
  • 9. Crysis 3, Far Cry 5
  • 10. Far Cry New Dawn, Far Cry Primal
  • 11. GTA V, Hitman 2
  • 12. Metro Exodus, RAGE 2
  • 13. Rise of Tomb Raider, Shadow of Tomb Raider
  • 14. Strange Brigade, Battlefield 1, Shadow of the Tomb Raider
  • 16. Score Card and Summary
  • 17. Closing Thoughts
MSI Gaming X Trio RTX 3060 Ti Review 85
Sound Level Test Results
MSI Gaming X Trio RTX 3060 Ti Review 86
System Power Consumption
To obtain accurate results we have connected the system to a Power Angle power meter that has in turn been attached to a 1500watt UPS. This ensures only 120volt power is supplied to the PSU and removes any variances that could potential crop up because of brownouts and power spikes.
MSI Gaming X Trio RTX 3060 Ti Review 87
Page 15 of 17
Tags: 3060TiGeforceMSIMSI Gaming X Trio RTX 3060 TiNvidiaRTX
Seagate Exos X18 Review
