It’s no Zotac Mini
in GPU, Recent, Reviews
MSI Gaming GeForce GTX 1630 4GB GDRR6 64-Bit HDMI/DP/DVI Single Fan OC ITX Graphics Card (GTX...
MSI Gaming GeForce GTX 1630 4GB GDRR6 64-Bit HDMI/DP/DVI Single Fan OC ITX Graphics Card (GTX 1630 AERO ITX 4G OC)
MSI Gaming GeForce GTX 1660 Super 192-bit HDMI/DP 6GB GDRR6 HDCP Support DirectX 12 Single Fan VR...
MSI Gaming GeForce GTX 1660 Super 192-bit HDMI/DP 6GB GDRR6 HDCP Support DirectX 12 Single Fan VR Ready OC ITX Graphics Card (GTX 1660 Super AERO ITX OC)
MSI Gaming GeForce GTX 1650 128-Bit HDMI/DP/DVI 4GB GDRR6 HDCP Support DirectX 12 VR Ready OC ITX...
MSI Gaming GeForce GTX 1650 128-Bit HDMI/DP/DVI 4GB GDRR6 HDCP Support DirectX 12 VR Ready OC ITX Graphics Card (GTX 1650 D6 AERO ITX OC)
11. Performance Summary and TL;DR
  • 12. Score Card and Summary
  • 13. Closing Statement
In an effort to make sorting through all the results as easy as possible we have combined the results all of all the game results into an easy to digest summary format. By comparing it to similar products in all the games you will be able to easily find the game(s) you are interested in, see the improvement and decide if it is the worth the investment.
MSI Aero ITX OC GTX 1070 Review 52
MSI Aero ITX OC GTX 1070 Review 53
TL;DR
As it blatantly obvious MSI had to make a lot of compromises in order to get a card that was even remotely ITX sized. Put another way sometimes small is just too small to get the job done. If your budget can stretch to the Zotac GTX 1070Ti Mini and your case can fit its longer length it is the better card. If your budget or case makes the Zotac Mini simply a non-starter the MSI is probably the best option left to you.
Page 11 of 13
Tags: aero 1070GTX 1070 minigtx1070MSImsi aeroMSI Aero ITX OC GTX 1070MSI Aero ITX OC GTX 1070: It’s no Zotac Minimsi vs zotacNvidiaNvidia GTX 1070
Intel Limited Edition i7 8086K Review
January 5, 2017
