It’s no Zotac Mini
in GPU, Recent, Reviews
MSI Gaming GeForce GTX 1630 4GB GDRR6 64-Bit HDMI/DP/DVI Single Fan OC ITX Graphics Card (GTX...
MSI Gaming GeForce GTX 1630 4GB GDRR6 64-Bit HDMI/DP/DVI Single Fan OC ITX Graphics Card (GTX 1630 AERO ITX 4G OC)
MSI Gaming GeForce GTX 1660 Super 192-bit HDMI/DP 6GB GDRR6 HDCP Support DirectX 12 Single Fan VR...
MSI Gaming GeForce GTX 1660 Super 192-bit HDMI/DP 6GB GDRR6 HDCP Support DirectX 12 Single Fan VR Ready OC ITX Graphics Card (GTX 1660 Super AERO ITX OC)
MSI Gaming GeForce GTX 1650 128-Bit HDMI/DP/DVI 4GB GDRR6 HDCP Support DirectX 12 VR Ready OC ITX...
MSI Gaming GeForce GTX 1650 128-Bit HDMI/DP/DVI 4GB GDRR6 HDCP Support DirectX 12 VR Ready OC ITX Graphics Card (GTX 1650 D6 AERO ITX OC)
10. Temperature, Noise, and Power Analysis
  • 12. Score Card and Summary
  • 13. Closing Statement
MSI Aero ITX OC GTX 1070 Review 49
Sound Level Test Results
MSI Aero ITX OC GTX 1070 Review 50
System Power Consumption
MSI Aero ITX OC GTX 1070 Review 51
Page 10 of 13
Tags: aero 1070GTX 1070 minigtx1070MSImsi aeroMSI Aero ITX OC GTX 1070MSI Aero ITX OC GTX 1070: It’s no Zotac Minimsi vs zotacNvidiaNvidia GTX 1070
Intel Limited Edition i7 8086K Review
