Home Games & Software
MiniTool Partition Wizard Pro
in Games & Software, Reviews
13-in-1 Multitool Hammer, Pohaku Multitool with DIY Stickers, Safety Lock, Screwdriver Bits Set...
13-in-1 Multitool Hammer, Pohaku Multitool with DIY Stickers, Safety Lock, Screwdriver Bits Set and Durable Nylon Sheath, Multi Tool for Outdoor, Camping, Ideal Gifts for Father, Husband, Boyfriend
Armytek Wizard C2 Pro Nichia Warm 1600 lm LED Headlamp
$99.00
2 new from $99.00
as of November 27, 2026 9:52 am
Autel Scanner MaxiCOM MK808Z: Android 11 Based Bi-Directional Control Scan Tool, 28+ Services,...
Autel Scanner MaxiCOM MK808Z: Android 11 Based Bi-Directional Control Scan Tool, 28+ Services, 2023 Upgraded of MK808/MX808, All System Diagnostics, FCA Auto Auth, ABS Bleed, Injector Coding
3. Power Data Recovery
  • 1. Mintool Partition and Data Recovery
  • 2. Partition Wizard Closer Look
  • 3. Power Data Recovery
  • 4. Feature Comparison
  • 5. Conclusion
wiz_data recovery
Moving on the other area which is a tad disappointing is the much hyped add-on ‘modules’. We would argue that these are not in fact add-on modules and instead represent an entirely separate program – it is even called MiniTool Data Recovery and not Partition Manager Data Recovery. Worse still this separate program is not included and has to be download from their website – hitting any of the features literally brings you to the same download page. If that is not bad enough, this separate program is a trial-ware version and if you want to purchase it you will not be given a discount for owning the Partition Manager! For a professional version some non-crippled version should be included.
undelete
On the positive side this separate module works, and works well. In testing it easily recovered accidentally deleted partitions, pictures, and even multimedia files. To be honest, it is arguably worth the asking price of $69 dollars, but having such blatant advertising built directly into a Professional software program does leave a bad taste in our mouths.
  • 5. Conclusion
Page 3 of 5
Previous 12345 Next
PNY GeForce GTX 980 XLR8 4GB
Crucial P5 Plus 2TB Review
September 23, 2021
