in Reviews, Ram
HyperX Fury RGB 128GB 2666MHz DDR4 CL16 DIMM (Kit of 4) HX426C16FB3AK4/128
HyperX Fury Black 16GB 2666MHz DDR4 CL16 DIMM Single Stick HX426C16FB4/16
Kingston Technology HyperX Impact 16GB 2666MHz DDR4 CL15 260-Pin SODIMM Laptop Memory...
Kingston Technology HyperX Impact 16GB 2666MHz DDR4 CL15 260-Pin SODIMM Laptop Memory (HX426S15IB2/16)
4. Kingston HyperX Fury DDR4-2666 32GB Kit – Benchmarking
  • 1. Kingston HyperX Fury DDR4-2666 32GB Kit – Introduction
  • 2. Kingston HyperX Fury DDR4-2666 32GB Kit – Specifications and Features
  • 3. Kingston HyperX Fury DDR4-2666 32GB Kit – Testing Methodology
  • 4. Kingston HyperX Fury DDR4-2666 32GB Kit – Benchmarking
  • 5. Kingston HyperX Fury DDR4-2666 32GB Kit – Load Time Tests
  • 6. Kingston HyperX Fury DDR4-2666 32GB Kit – GTA V FPS Test
  • 7. Kingston HyperX Fury DDR4-2666 32GB Kit – Score Card and Summary
  • 8. Kingston HyperX Fury DDR4-2666 32GB Kit – Closing Statement
AIDA64 Benchmark
AIDA64 Extreme Edition is a diagnostic and benchmarking software suite for home users that provides a wide range of features to assist in overclocking, hardware error diagnosis, stress testing, and sensor monitoring. It has unique capabilities to assess the performance of the processor, system memory, and disk drives.
The benchmarks used in this review are the memory bandwidth and latency benchmarks. Memory bandwidth benchmarks (Memory Read, Memory Write, Memory Copy) measure the maximum achievable memory data transfer bandwidth. The code behind these benchmark methods are written in Assembly and they are extremely optimized for every popular AMD, Intel and VIA processor core variants by utilizing the appropriate x86/x64, x87, MMX, MMX+, 3DNow!, SSE, SSE2, SSE4.1, AVX, and AVX2 instruction set extension.
The Memory Latency benchmark measures the typical delay when the CPU reads data from system memory. Memory latency time means the penalty measured from the issuing of the read command until the data arrives to the integer registers of the CPU.
Kingston HyperX Fury DDR4-2666 32GB Kit 11Kingston HyperX Fury DDR4-2666 32GB Kit 12
SuperPI Benchmark
SuperPi calculates the number of digits of PI in a pure 2D benchmark. For the purposes of this review, calculation to 32 million places will be used. RAM speed, RAM timings, CPU speed, L2 cache, and Operating System tweaks all effect the speed of the calculation, and this has been one of the most popular benchmarks among enthusiasts for several years.
SuperPi was originally written by Yasumasa Kanada in 1995 and was updated later by snq to support millisecond timing, cheat protection and checksum. The version used in these benchmarks, 1.5 is the official version supported by hwbot.
Kingston HyperX Fury DDR4-2666 32GB Kit 13Consumers who feel that DDR4-2666 is just not fast enough, the fact that it is down right simple to hit DDR4-3200 makes this kit all the more impressive. By the same token, the zero hassle factor DDR4-2666 does have a lot to be said for it. Quite litteraly this kit will (probably) never run at stock DDR4-2133 speeds. Instead it will run at 2666.. albeit with looser timings. Either way this kit really will cover a lot of consumers needs nicely.
FAHBench 1.2.0
With Folding@home becoming more popular, and since folding performance is a fairly memory intensive endeavor this makes it a great option for showing how performance is impacted by RAM performance. The official FAHBench includes numerous options but we have opted to use the OpenCL CPU option and test first with implicit modeling and then explicit.
Kingston HyperX Fury DDR4-2666 32GB Kit 14
WinRAR x64
WinRAR is by far one of the most popular compression and archival utilities commercially available today. As it memory intensive it is also extremely useful in evaluating the overall performance of the RAM sample. For repeatability we have opted for the built-in benchmark processing 1,000MB of data.
Kingston HyperX Fury DDR4-2666 32GB Kit 15
CineBench R15
CINEBENCH is a real-world cross platform test suite that evaluates your computer’s performance capabilities. CINEBENCH is based on MAXON’s award-winning animation software CINEMA 4D, which is used extensively by studios and production houses worldwide for 3D content creation.
In this system benchmark section, we will use the x64 Main Processor Performance (CPU) test scenario. The Main Processor Performance (CPU) test scenario uses all of the system’s processing power to render a photorealistic 3D scene (from the viral “No Keyframes” animation by AixSponza). This scene makes use of various algorithms to stress all available processor cores. The test scene contains approximately 2,000 objects which in turn contain more than 300,000 polygons in total, and uses sharp and blurred reflections, area lights, shadows, procedural shaders, antialiasing, and much more. The result is displayed in points (pts). The higher the number, the faster your processor.
Kingston HyperX Fury DDR4-2666 32GB Kit 16We honestly doubt most consumers will find DDR4-2666 speeds lacking, but once again kicking this kit into overdrive is so darn simple that it is almost a shame to not gain that extra little bit of performance that DDR4-3200 offers!
Page 4 of 8
X99A GAMING PRO CARBON with front USB 3.1 Type-C and U.2 is here!
May 9, 2014
