IronWolf Pro 125 Review
10.   Boot time and Data Transfer
  • 4. BiCS NAND Primer
  • 9.   IOMeter
System Boot Time
IronWolf Pro 125 Review 35
Real World Data Transfers
IronWolf Pro 125 Review 36
IronWolf Pro 125 Review 37
  • 9.   IOMeter
Page 10 of 15
May 9, 2014
