Home Processors (CPU)
Intel Core i9-11900K and Core i5-11600K Review
in Processors (CPU), Reviews
11th Gen Intel Rocket Lake-S
Intel Core i9-11900K Desktop Processor 8 Cores up to 5.3 GHz Unlocked LGA1200 (Intel 500 Series &...
Intel Core i9-11900K Desktop Processor 8 Cores up to 5.3 GHz Unlocked LGA1200 (Intel 500 Series & Select 400 Series Chipset) 125W
$659.78
3 new from $659.78
3 used from $385.00
as of March 28, 2026 10:12 pm
Intel® Core™ i9-11900KF Desktop Processor 8 Cores up to 5.3 GHz Unlocked LGA1200 (Intel® 500...
Intel® Core™ i9-11900KF Desktop Processor 8 Cores up to 5.3 GHz Unlocked LGA1200 (Intel® 500 Series & Select 400 Series Chipset) 125W
$439.00
2 new from $439.00
7 used from $305.00
Intel Core i9-10900K Desktop Processor 10 Cores up to 5.3 GHz Unlocked LGA1200 (Intel 400 Series...
Intel Core i9-10900K Desktop Processor 10 Cores up to 5.3 GHz Unlocked  LGA1200 (Intel 400 Series Chipset) 125W
$640.00
3 new from $640.00
3 used from $329.99
Last updated on March 28, 2026 10:12 pm
8. x264 HD and Handbrake
  • 1. The I’s have it? Or Have had it?
  • 2. Closer Look
  • 3. Test Bed
  • 4. Adobe Performance
  • 5. Cinebench & Geekbench Results
  • 6. PCMark, POV-Ray, Blender
  • 7. winRAR and TrueCrypt
  • 8. x264 HD and Handbrake
  • 9. AC:S & BF4
  • 10. Crysis 3, GTA V, Metro LL
  • 11. Analysis of Mainstream Consumer CPU options
  • 12.   Closing Thoughts
x264 HD Benchmark
Intel Core i9-11900K and Core i5-11600K Review 21
Handbrake X265
HandBrake is a free and open-source transcoder for digital video files, originally developed in 2003 by Eric Petit. Since then it has continued to evolve. Included in its list of features is the ability to transcode existing video from x264/MPEG-4 AVC to x265/HEVC. For this test we are using a one hour length 4K x264 file and using the H.265 MKV 1080p30 preset transcoding it to 1080p resolution.
Intel Core i9-11900K and Core i5-11600K Review 22
  • 2. Closer Look
  • 3. Test Bed
  • 9. AC:S & BF4
Page 8 of 12
Tags: Core i5-11600KIntel Core i9-11900KIntel Core i9-11900K and Core i5-11600K
Synology DiskStation DS1621 Plus Review
Corsair 5000D Review
