EVGA GTX 1080Ti SuperClocked
Black Edition: Surprisingly Full of Value
in GPU, Recent, Reviews
EVGA GeForce GTX 1080 Ti SC Black Edition Gaming, 11GB GDDR5X, iCX Cooler & LED, Optimized...
EVGA GeForce GTX 1080 Ti SC Black Edition Gaming, 11GB GDDR5X, iCX Cooler & LED, Optimized Airflow Design, Interlaced Pin Fin Graphics Card 11G-P4-6393-KR (Renewed)
EVGA GeForce GTX 1070 SC GAMING ACX 3.0 Black Edition, 8GB GDDR5, LED, DX12 OSD Support (PXOC)...
EVGA GeForce GTX 1070 SC GAMING ACX 3.0 Black Edition, 8GB GDDR5, LED, DX12 OSD Support (PXOC) 08G-P4-5173-KR (Renewed)
EVGA GeForce GTX 1660 SC Ultra Gaming, 06G-P4-1067-KR, 6GB GDDR5, Dual Fan
11. Temperature, Noise, and Power Analysis
  • 3. A Closer Look
  • 6. Mining
  • 7. AC:Syndicate, Batman: AK, BF 4
  • 9. GTA V, Hitman, Rise of Tombraider
  • 11. Temperature, Noise, and Power Analysis
  • 12. Performance Summary and TL;DR
  • 13. Score Card and Summary
  • 14. Closing Statement
EVGA GTX 1080Ti SuperClocked 48
Sound Level Test Results
EVGA GTX 1080Ti SuperClocked 49
System Power Consumption
EVGA GTX 1080Ti SuperClocked 50
With its combination of ‘only’ two fans and ball-bearing based fans at that (which are indeed longer lasting but not as silent) it should come as no surprise that the EVGA GeForce GTX 1080Ti SC BE is louder than its more expensive siblings. By the same token it is not that much louder and under more normal circumstances barely audible. Put another way it may be louder than some but that is not the same as saying it is loud. Just not ‘silent’. As for its cooling abilities… the results do speak for themselves. EVGA really knocked it out of the park with their new ‘ICX’ design. In the power department… you either can ‘afford’ to have a 250watt beast running or you cannot. Overall we have seen bigger power hog – as well as more ‘fuel efficient’ – models but overall the Black Edition SuperClock is pretty darn decent all things considered.
  • 3. A Closer Look
  • 6. Mining
Page 11 of 14
Tags: EVGAGraphics CardGTX 1080 TiGTX1080tiNvidia
Silicon Power Armor A62 Review
