EVGA GTX 1070 FTW DT Review
Red-headed stepchild or red-hot deal?
in GPU, Recent, Reviews
EVGA GeForce GTX 1070 FTW GAMING ACX 3.0, 8GB GDDR5, RGB LED, 10CM FAN, 10 Power Phases, Double...
EVGA GeForce GTX 1070 FTW GAMING ACX 3.0, 8GB GDDR5, RGB LED, 10CM FAN, 10 Power Phases, Double BIOS, DX12 OSD Support (PXOC) Graphics Card 08G-P4-6276-KR (Renewed)
EVGA GeForce GTX 1070 FTW DT GAMING ACX 3.0, 8GB GDDR5, RGB LED, 10CM FAN, 10 Power Phases,...
EVGA GeForce GTX 1070 FTW DT GAMING ACX 3.0, 8GB GDDR5, RGB LED, 10CM FAN, 10 Power Phases, Double BIOS, DX12 OSD Support (PXOC) Graphics Card 08G-P4-6274-KR
EVGA GeForce GTX 1080 SC GAMING ACX 3.0, 8GB GDDR5X, LED, DX12 OSD Support (PXOC) Graphics Card...
EVGA GeForce GTX 1080 SC GAMING ACX 3.0, 8GB GDDR5X, LED, DX12 OSD Support (PXOC) Graphics Card 08G-P4-6183-KR (Renewed)
10. Temperature, Noise, and Power Analysis
  • 3. A Closer Look
  • 12. EVGA GTX 1070 FTW DT: Score Card and Summary
  • 13. Closing Statement
EVGA GTX 1070 FTW DT Review 43
Sound Level Test Results
EVGA GTX 1070 FTW DT Review 44
System Power Consumption
EVGA GTX 1070 FTW DT Review 45
For an ACX based design the EVGA GeForce GTX 1070 FTW DT does have a lot going for it. Thanks to reference stock speeds it does – relatively speaking – sip power, is a very quiet video card, and is rather pretty. On the other hand at retail prices it may not glitter like gold for you. So take its rep with a grain of salt and see if its abilities do indeed line up with what you want it to be… and go from there.
  • 3. A Closer Look
Page 10 of 13
Tags: EVGAEVGA GTX 1070 FTW DTGTXGTX 1070GTX 1070 ReviewNvidiareview
Ballistix SPORT AT DDR4-3000 Review
Lexar 3400x Cfast 2.0
July 21, 2015
Intel Innovation 2023
September 19, 2023
