in Reviews, Ram
5. DDR5 Primer P.3
  • 3. DDR5 Primer P.1
  • 4. DDR5 Primer P.2
  • 5. DDR5 Primer P.3
  • 6. Closer Look P.1
  • 8. Adobe Performance
  • 9. Blender & Cinebench
  • 10. DaVinci & Handbrake
  • 11. POV-Ray & OpenSCAD
  • 12. SolidWorks & WinRAR
Crucial Pro DDR5-5600 128GB Review 14
Another important change is the lower voltage requirements of DDR5 when compared to DDR4. While yes a ‘mere’ 0.1-volt reduction does not sound like much it does have a noticeable real-world impact, as it is an 8.7 percent reduction in electricity and thus an 8.7 percent reduction in heat. Sure, this reduction will mostly be noticed by mobile computer owners rocking DDR5 systems and enterprise owners rocking an untold number of RAM in a server farm but less waste heat is always better.
Crucial Pro DDR5-5600 128GB Review 15
Going hand in hand with this decrease in heat output onboard temperature sensors are now part of the JEDEC standard. Yes, many a kit of Crucial DDR4 RAM came with temperature sensors onboard, but now you can rest assured that no matter what DDR5 kit you buy it will have the ability to thermally limit itself in the event of system builder idiocy (and/or cooling fan failure).
One of the biggest changes from DDR4 to DDR5 (beyond speed increase and future potential performance) is how the DIMMS are fed a clean, stable diet of power. DDR4 relied solely on your motherboard and its ability to properly regulate voltages. This leads to… variability with some boards being better than others at this critical, dare we say crucial, task. With DDR5, JDEC removed this variability by making it the DDR5 DIMMS job to feed its own RAM ICs the proper voltage. That is why if you look closely at a stick of DDR5 RAM you will see a little cluster of mosfets and a tiny controller – a Power Management IC (“PMIC”). Thus, the voltage provided to each DIMM will be more precise, and more stable than the motherboard method.
There certainly is a lot to like, or at least potential, when it comes to DDR5. Sadly, and much like when DDR4 arrived on the scene, it is not all sunshine and roses. Going hand in hand with a moderate to major increase in performance is an increase in latency and a decrease in stability at higher speeds with those denser ICs. For most the latency really is a non-issue. Yes. The absolute best DDR5 you can find (and can afford) has a CAS latency of 30. Most are in the 38-45+ range. For people used to DDR4 CL numbers, those are big, whopping numbers. Thankfully a DDR5 “CL40” is not the same as CL40 with DDR4. For example, DDR5-4800 CL40 has the exact same 16.67ns latency as DDR4-2400 at CL20. DDR5-6400 CL40 has the exact same 12.5ns latency as DDR4-3200 at CL20. So while it will take time for CAS Latency numbers to fall the latency penalty a non-issue (for most).
The same is somewhat true for 64GB and 96GB 2stick DDR5 RAM kits. Yes, they are not going to be hitting massive frequencies that 2x16GB kits can do anytime soon, but the overall performance is noticeably better than 64 or 96GB kits during the DDR4 days. It is better because it only takes 2 DIMMS populated to hit that capacity versus four DIMMS populated back in the DDR4 days. So much like with latency numbers, things are getting better and better every year and with time this ongoing issue will become smaller and smaller. Hopefully.
5. DDR5 Primer P.3
Page 5 of 15
