in Reviews, Ram
11. POV-Ray & OpenSCAD
  • 3. DDR5 Primer P.1
  • 4. DDR5 Primer P.2
  • 5. DDR5 Primer P.3
  • 6. Closer Look P.1
  • 8. Adobe Performance
  • 9. Blender & Cinebench
  • 10. DaVinci & Handbrake
  • 11. POV-Ray & OpenSCAD
  • 12. SolidWorks & WinRAR
POV-Ray Benchmark
The Persistence of Vision Ray Tracer, or POV-Ray, is a ray tracing program which generates images from a text-based scene description, and is available for a variety of computer platforms.
Intel:
Crucial Pro DDR5-5600 128GB Review 37
AMD:
Crucial Pro DDR5-5600 128GB Review 38
OpenSCAD “Pistol” Rendering Benchmark
This benchmark combines the power of OpenSCAD (https://openscad.org/) with a custom rendering script created, and maintained by Michael Larabel (https://www.michaellarabel.com/). It is part of the “Phoronix Test Suite” (https://github.com/phoronix-test-suite). This fairly quick benchmark runs a custom script that times how long it takes to render the ‘Pistol” SCAD asset(s) to PNG output. All tests are run 5 times with the average result in seconds displayed.
Intel:
Crucial Pro DDR5-5600 128GB Review 39
AMD:
Crucial Pro DDR5-5600 128GB Review 40
Page 11 of 15
Silicon Power XS70 1TB Review
