Crucial P310 2280 Edition 2TB Review
Same great taste, now more filling (of the M.2 slot)
Crucial P310 2TB 2280 PCIe Gen4 3D NAND NVMe M.2 SSD – Up to 7,100 MB/s – Shift up to Gen4, with...
Crucial P310 2TB 2280 PCIe Gen4 3D NAND NVMe M.2 SSD – Up to 7,100 MB/s – Shift up to Gen4, with Acronis Offer, Internal Solid State Drive (PC) – CT2000P310SSD801
6. Sequential Performance
Read Bandwidth
Crucial P310 2280 Edition 2TB Review 25
Write Performance
Crucial P310 2280 Edition 2TB Review 26
Page 6 of 15
Tags: 2280 form-factoraffordable SSD PCIe 4.0budget-friendly SSDCrucial P310QLC NANDSSDSSD performancestorage upgrade
AData SC740 1TB Review
The Witcher 2
The Witcher 2
April 22, 2015
Synology DS1520+ Review
