Crucial P310 2280 Edition 2TB Review
Same great taste, now more filling (of the M.2 slot)
Crucial P310 2TB 2280 PCIe Gen4 3D NAND NVMe M.2 SSD – Up to 7,100 MB/s – Shift up to Gen4, with...
Crucial P310 2TB 2280 PCIe Gen4 3D NAND NVMe M.2 SSD – Up to 7,100 MB/s – Shift up to Gen4, with Acronis Offer, Internal Solid State Drive (PC) – CT2000P310SSD801
4. Closer Look
Crucial P310 2280 Edition 2TB Review 16
As this is both a Crucial branded model… and a “2280 edition” of an existing model it should come as no surprise that while the heat-sink edition is noticeably thicker the shipping containers for both variants are basically the same as the standard / original P310’s box. That is to say their combination of white background, blue font, and nicely sized picture of the M.2 SSD housed inside Just Works™. Yes. It is on the conservative side. In fact, one could argue that Crucial’s almost aggressiveness in their conservatives makes them stand out more than the flash-n-dash boxes most other companies use.
Crucial P310 2280 Edition 2TB Review 17
Moving on. The interior packaging is similar but not the same as the standard P310 series. That is to say while it does rely upon a two piece, plastic ‘clamshell’ style interior ‘house’ the P310 2280 lacks the duality of the OG/2230 P310 series. Which is fine. This is not a 22x30mm model where the design team foresaw the need for not only 2280 adapters… but housing both inside the original packaging. Put another way, the P310 2280 versions use the ‘standard’ Crucial clamshell and that is perfectly acceptable for 2280 sized M.2 drives. The standard option uses a ‘defense in depth’ strategy that has been shown to work well in the past and has proven itself more than capable of handling the (typical) bumps and bruises Ye Olde Angry Shipping Agent will inevitably inflict on this box while it is in their… ‘tender mercies’.
Crucial P310 2280 Edition 2TB Review 18
For those who have not read up on the original P310 the P310 2280s components may come as a bit of surprise. Ironically… those who have read our previous P310 2230 2TB review will equally be surprised by some of Crucial’s design decisions. Let’s start with the core components and go over what has changed and not changed… as this is a very interesting model to say the least.
Crucial P310 2280 Edition 2TB Review 19
First up you have the controller. The new(ish) PCIe 4.0 x 4 Phison E27T controller is actually a very good choice for this more budget minded model. After all, the E27T’s combination of 4-channels with DRAM-Less abilities makes for a much more palatable purchase for Crucial. In fact, when purchased by not by the pallet or even tractor trailer load… but at the weekly (possibly even monthly) factory output levels the per IC price is not what anyone would consider a large impact on the P310 series build cost.
Crucial P310 2280 Edition 2TB Review 20
Furthermore where there are only 4 channels to populate, with each one only needing 3600MT/s to be saturated, and it only has to hit “good enough” performance levels by PCIe 4.0 standards, which is easily accomplished by Microns N58R QLC NAND, this is a model that can be consider fast enough and inexpensive enough to satisfy a wide range of build’s secondary and in some cases primary storage needs.
Crucial P310 2280 Edition 2TB Review 21
So yes. You will not find a DDRx RAM IC on the PCB. Yes. You will not find a virtual ton of NAND ICs either.
Crucial P310 2280 Edition 2TB Review 22
All of which will come as little surprise to those who already know about the P310 series. What will be surprising is the fact that Crucial has not taken the time to minimize the lack of NAND ICs that accompany 2230 form-factor standards. Yes. Just as with the original P310 2TB, the 2280 edition only makes use of one NAND IC. Ugh. This is not a good thing. At all.
Crucial P310 2280 Edition 2TB Review 23
We completely understand why the OG P310 needed to rely upon only a single NAND IC… as it is designed for devices which not only demand a 22×30 form-factor but also a single sided one at that. Thus no room for even a second NAND IC. With 22×80 form-factor there is zero good reasons to not at the very least include a second NAND IC. Heck, in the 2280 M.2 NVMe marketplace dual sidedness is not that big a deal. Thus there was room for not one extra, not two extra… but three extra. Which would have allowed the P310 2280 edition the luxury of having each of the 27T’s four channels directly connected to an entire NAND IC and not just a couple dies worth on one single NAND IC.
Why would that matter, and why do we consider this a major misstep by Crucial? Simple. Saturation of the CMOS baked in the NAND IC itself. Under normal ‘d drive’ conditions the chances of the single CMOS worth of electronics being noticeably overwhelmed by I/O requests are minor. Outside of massive, p-SLC write cache exhausting write requests… it probably just will not happen. As a ‘C’ drive that is running a modern OS? Yeah. Even excluding the SmartFlush alogs that will try and keep ahead of p-SLC write buffer exhaustion (that cause Phison drives to have a ‘classic’ 3 tier / steps write performance levels)… I/0 requests can indeed make that one CMOS worth of electronics be the bottleneck that limits the E27T. That is something no 2280 drive should ever suffer from. The small 4 channel controller and its lack of on PCB cache should be the limiting factor. What a missed opportunity to say the least.
Crucial P310 2280 Edition 2TB Review 24
More puzzling still is the fact that is blatantly obvious that Crucial did take the time to rearrange the PCB circuity. So it is not like this is just a P310 with factory 2280 adapter baked directly into it or anything. In fact, if you look closely at the PCB you can see that not only did the rearrange the circuitry… the had to mod’ their existing 2280 PCB so as to work with the QLC NAND’s smaller footprint! IE It is straight up installed in a E/W orientation when the PCB already had N/S contact points built into it… as that is what most 2280s do, including Crucial’s P5, T500, and T7xx series. Strange.
On the positive side, this is a much easier to install in the typical PC storage device than its lil’ bro 310 2230. So much so that, unlike the P310 2230 series, it is Plug and Play simple. Which is a good thing as that is the standard upon which all 2280 SSDs (including SATA) have to meet.
Also on the positive side is this is a model that sips power and creates very little heat. So much so it makes its more expensive sibling the T500 series seem greedy by comparison. As such this is basically a drive that can be cooled with potato level cooling. Hell. If you do not push it too hard and use it mostly as a read (nearly) only ‘D’ drive it could probably get by without any heat sinks. Something the T500 series can also not do.
Equally important, is the P310 series is tailormade for 2280 form-factor builds where internal case airflow is not exactly ‘great’ and in fact can be nearly non-existent. In such builds even the cool running T500 can run into issues and yet the (under 7mm z-height above the PCB and under 2mm below it) P310 heatsink edition is more than up to the task of keeping the few components cool. In testing on an open bench with no airflow at all the P310 2TB heatsink option never once thermally limited. Furthermore, when only a smidgen of waste air (from a downdraft CPU cooler we may add) it never even got hot to the touch. That is indeed impressive. Especially for entry level builds where the motherboard options don’t precisely come with great integrated M.2 heatsinks for the secondary M.2 slots.
Equally impressive is these little P310s are rather fun to RAID and two of the inexpensive 2TB’ers can easily make for one potent 4TB scratch disk for video editions. One where you will get better than NVMe PCIe 5.0 performance for very little cash.
Taken as a whole. The P310 2280 does indeed have a lot going for it and with a little outside the box thinking can make for a rather decent to great solution to a variety of problems.
4. Closer Look
Page 4 of 15
Tags: 2280 form-factoraffordable SSD PCIe 4.0budget-friendly SSDCrucial P310QLC NANDSSDSSD performancestorage upgrade
AData SC740 1TB Review
January 5, 2017
