Crucial Ballistix Sport LT Red 32GB Kit
in Reviews, Ram
Crucial Ballistix Sport LT 3200 MHz DDR4 DRAM Desktop Gaming Memory Single 16GB CL16...
Crucial Ballistix Sport LT 3200 MHz DDR4 DRAM Desktop Gaming Memory Single 16GB CL16 BLS16G4D32AESE (Red)
Crucial Ballistix Sport LT 2666 MHz DDR4 DRAM Laptop Gaming Memory Single 8GB CL16 BLS8G4S26BFSD...
Crucial Ballistix Sport LT 2666 MHz DDR4 DRAM Laptop Gaming Memory Single 8GB CL16 BLS8G4S26BFSD (Gray)
$117.77
1 used from $49.99
as of March 30, 2026 2:32 am
3. Crucial Ballistix Sport LT DDR4 Memory
  • 1. Crucial Ballistix Sport LT Red – Introduction
  • 2. Crucial Ballistix Sport LT Red – Specifications and Features
  • 3. Crucial Ballistix Sport LT DDR4 Memory
  • 4. Crucial Ballistix Sport LT Red – Closer Look
  • 5. Crucial Ballistix Sport LT Red – Testing Methodology
  • 6. Crucial Ballistix Sport LT Red – Overclocking
  • 7. Crucial Ballistix Sport LT Red – Score Card and Summary
  • 8. Crucial Ballistix Sport LT Red – Closing Statement
Product highlights
  • Speeds start at 2400 MT/s
  • Faster speeds and responsiveness than standard Crucial DDR4 memory
  • Ideal for gamers and performance enthusiasts
  • Four channel memory architecture maximizes data rates
  • Digital camo heat spreader available in white, gray and red
  • Easy plug-and-play installation
  • Intel® XMP 2.0 profiles for easy configuration
  • Optimized for the latest Intel platforms
  • Limited lifetime warranty
Speed. Style. Sport. Get more out of your memory.
Designed for performance enthusiasts, gamers, and anyone who simply wants to get more out of their system, Crucial Ballistix Sport LT DDR4 memory helps you do just that. Give your processor the resources it needs to perform and make your computer faster and more responsive.
Make your system go Ballistix.
Crucial Ballistix Sport LT Red 32GB Kit 13Memory is fun when it’s faster, when it’s stylish, and when it helps your system perform at a higher level. Compared to standard Crucial DDR4 memory, that’s exactly what Ballistix Sport is engineered to do. Get faster speeds and run demanding applications with ease. Multitask at will with increased bandwidth. And strike first with better latencies and reduced load times.
Install with ease.
Crucial Ballistix Sport LT Red 32GB Kit 14Getting more out of your system should be easy — and that’s exactly how we engineered Ballistix Sport memory. Using cutting-edge technology, intuitive module design, Intel® XMP 2.0 profiles and more, we designed Ballistix Sport with the sole intent of creating affordable, easy-to-use performance memory. Installation is a cinch: just plug-and-play, and get ready to win with little to no BIOS configuration.
Go covert.
Crucial Ballistix Sport LT Red 32GB Kit 15With a stealth digital camo design and integrated heat spreader, Ballistix Sport LT is designed to be your memory lieutenant. Keep your system cool and collected while mowing down the opposition — whether that’s a challenging spreadsheet or an opponent you’ve just reduced to a bloody pulp.
Micron® quality—a higher level of reliability.
As a brand of Micron, one of the largest memory manufacturers in the world, Ballistix memory is built to last and delivers a higher level of performance than standard memory. For more than 35 years, we’ve engineered old-school DDR memory all the way to Ballistix Sport DDR4, which empowers you to seize an affordable performance edge. Backed by a limited lifetime warranty and rigorously tested to some of the most demanding standards in the industry, Ballistix Sport LT DDR4 memory has been thoroughly proven and is ready to make an immediate impact in your system.
Page 3 of 8
Computex Highlights so far
Corsair 5000D Review
