ASRock Challenger B570 10GB OC Review
Injection of Sanity into the GPU Marketplace
in Reviews, GPU
14. Temperature, Noise, and Power Analysis
  • 2. Closer Look p.1
  • 3. Overclocking
  • 5. AC: Mirage, Cyberpunk 2077
  • 6. Battlefield 5, CoD: MWII
  • 7. Crysis 3, Far Cry 6
  • 8. GTA V, Hitman 3
  • 9. Metro Exodus, S.T.R.
  • 10. The Division 2, Watch Dogs: Legion, Witcher 3
  • 11. Ray Tracing Performance
  • 12. Adobe PP & Blender
  • 13. DaVinci, Handbrake, Topaz AI
  • 15. Closing Thoughts
ASRock Challenger B570 10GB OC Review 58
Sound Level Test Results
While everyone “hears” noise differently there is one easy way to remove all subjectiveness and easily compare different fans: use a sound level meter. This way you can easily compare the various fans noise envelopes without us coloring the results and see what fans fit within your personal comfort level. Of course, we will endeavor to try and explain the various results – which are taken at a 15-inch distance from the GPU’s fan(s) – to help you gain an even better understanding of how loud a cooler’s stock fan is, but even if you discount our personal opinions, the fact remains numbers don’t lie.
ASRock Challenger B570 10GB OC Review 59
System Power Consumption
To obtain accurate results we have connected the system to a Power Angle power meter that has in turn been attached to a 1500watt UPS. This ensures only 120volt power is supplied to the PSU and removes any variances that could potentially crop up because of brownouts and power spikes.
ASRock Challenger B570 10GB OC Review 60
  • 3. Overclocking
Page 14 of 15
Tags: 1080p gamingArc GPUsASRock Challenger B570ASRock GPUsBudget gamingentry-level GPUsgaming hardwareGPUGPU industryGraphics cardsIntel ArcIntel BattleMageOverclockingPC gamingPC gaming budgetPC gaming trendsvalue GPUs
MSI GE76 Raider 12U Review
USB 3.0 cables go optic
April 22, 2014
