So advanced it may just be an Alien Life Form 3.0
in Cooling, Reviews
ARCTIC Liquid Freezer III 420 A-RGB - CPU AIO Water Cooler, Water Cooling PC, Intel & AMD,...
ARCTIC Liquid Freezer III 420 A-RGB - CPU AIO Water Cooler, Water Cooling PC, Intel & AMD, Efficient PWM-Controlled Pump, Fan: 200–1900 RPM, LGA1851 and LGA1700 Contact Frame - Black
ARCTIC Liquid Freezer III 420 - CPU AIO Water Cooler, Water Cooling PC, Intel & AMD, Efficient...
ARCTIC Liquid Freezer III 420 - CPU AIO Water Cooler, Water Cooling PC, Intel & AMD, Efficient PWM-Controlled Pump, Fan: 200–1700 RPM, LGA1851 and LGA1700 Contact Frame - Black
5. Testing Methodology
  • 4. Installation Issues
This different approach starts with testing on two testbeds and not just one. The first is an Intel 13th generation Core i9-13900K CPU. This CPU’s thermal characteristics make it a good representation of for what most upper-mainstream users will experience. For AMD fans, we have an older Zen 3 Ryzen 9 5950X processor. A processor that just does not like to run cool.
Further helping to give as clear a picture of a given cooler’s real-world performance, we also will be testing a test sample with stock number of fans (i.e. whatever number is included in the box), and (when possible) the maximum number of fans. For most air-based coolers this means one fan for stock, and two to three for maximum results; whereas with water-based stock could be one to three, and three to six for maximum.
Since not all fans are made the same, we will also be testing the review sample at various fans speeds. While many can go below 800rpms few will not spin at below this level and fewer still do so while keeping temperatures in check. This is why we have chosen 800RPM as the minimum fan speed cut-off, and from then on we increase the rotational speed in 200 to 250 RPM increments until the fan is running at ‘full speed’. This can vary from 1200 to over 3000… and will help highlight how much – or little – extra performance the increase in rotational speed brings to the table. Our personal cut off for CPU temperature is 90 degrees, but to give as full a picture as possible we have opted (when possible) for 95 C as the cutoff and as such once 95-degree temperature results are reached no further results below that fan speed will be included.
Intel Testbed:
Memory: Crucial Pro DDR5-5600
Cooling: Various
Power Supply: Corsair AX860i
Monitor: Dell U2714H
OS: Windows 11 Professional
AMD Testbed:
Processor: AMD Ryzen 9 5950X
Cooling: Various
Page 5 of 9
Tags: 420 White A-RGBAIO CPU CoolerAll-In-One CoolerArctic CoolingArctic Liquid Freezer IIIComputer Hardware ReviewCooling PerformanceCPU Cooler Reviewcpu coolingLiquid CoolingLiquid Freezer III SeriesOverclockingPC BuildingPC ComponentsPC Cooling SolutionsPC EnthusiastPremium CoolingRadiator DesignVRM Coolingwater cooling
Intel Unveils Arc B-Series Battlemage Graphics Cards
