Arctic Alpine 17 LP Review
ARCTIC Alpine 17 LP - Low-Profile CPU Cooler for Intel LGA 1700, 92 mm PWM Fan, Low Installation...
ARCTIC Alpine 17 LP - Low-Profile CPU Cooler for Intel LGA 1700, 92 mm PWM Fan, Low Installation Height: 42.9 mm, 4-pin Connection, 300-3000 RPM, Tool-Free Push-pin Installation, top Blower
5. Testing Methodology
  • 1. Why bother with an RS1 when you can have an Alpine?
While there are many, many ways of properly and efficiently testing CPU cooling solutions not every method will offer useful information for all potential buyers. Some consumers care more about noise than shear performance (aka ‘Silent PC’ enthusiasts). Others only care about performance and do not mind in the least if the cooler is as loud as a jet plane. Others still want to know how flexible a cooler is and how effective it will be at moderate – not silent – noise levels. Most though fall somewhere in the middle and want a good all-round design.
This different approach starts with testing the review sample with stock number of fans (i.e. whatever number is included in the box), and (when possible) the maximum number of fans. For most air-based coolers this means one fan for stock, and two to three for maximum results; whereas with water-based stock could be one or two, and two to four for maximum.
Since not all fans are made the same, we will also be testing the review sample at various fans speeds. While many can go below 800rpms few will not spin at below this level and fewer still do so and keep temperatures in check. This is why we have chosen 800RPM as the minimum fan speed cut-off, and from then on we increase the rotational speed in 200 to 250 RPM increments until the fan is running at ‘full speed’. This can vary from 1200 to over 3000… and will help highlight how much – or little – extra performance the increase in rotational speed brings to the table. Our personal cut off for CPU temperature is 90 degrees and as such once 90-degree average is reached no further results below that fan speed will be included.
Consumer Testbed:
Processor: Intel Core i5-12600K PL1 & PL2 locked at wattage stated in the chart
Memory: 32GB Crucial Desktop Memory DDR5-4800
Motherboard: Gigabyte Aorus Pro Z690
Cooling: Various
SSD: 1x Silicon Power XS70 1TB NVMe SSD
Power Supply: Corsair AX860i
Page 5 of 9
Tags: 17 LPAlpineArcticARCTIC Alpine 17 LPLow-Profile CPU Cooler
