MSI GTX 980Ti Lightning: The Silent Assassin
in GPU, Reviews
MSI Gaming GeForce GTX 1660 Super 192-bit HDMI/DP 6GB GDRR6 HDCP Support DirectX 12 Dual Fan VR...
MSI Gaming GeForce GTX 1660 Super 192-bit HDMI/DP 6GB GDRR6 HDCP Support DirectX 12 Dual Fan VR Ready OC Graphics Card (GTX 1660 Super VENTUS XS OC)
$249.00
$280.00
6 new from $249.00
4 used from $164.99
as of December 28, 2025 10:32 am
MSI Computer Video Graphic Cards GeForce GTX 1050 TI GAMING X 4G, 4GB
$329.87
2 new from $329.87
1 used from $228.15
MSI Gaming GeForce GTX 1660 Super 192-bit HDMI/DP 6GB GDRR6 HDCP Support DirectX 12 Dual Fan VR Ready OC Graphics Card (GTX 1660 Super Gaming X)
$375.00
6 new from $375.00
3 used from $198.00
Last updated on December 28, 2025 10:32 am
17. MSI 980Ti Lightning – Overclocking
  • 1. MSI 980Ti Lightning – Introduction
  • 2. MSI 980Ti Lightning – Specs and Features
  • 3. MSI 980Ti Lightning – GeForce GTX 980Ti explained
  • 4. MSI 980Ti Lightning – A Closer Look
  • 5. MSI 980Ti Lightning – Testing Methodology
  • 6. MSI 980Ti Lightning – Sleeping Dogs (SGB)
  • 7. MSI 980Ti Lightning – Metro: Last Light (SGB)
  • 8. MSI 980Ti Lightning – BioShock Infinite (SGB)
  • 9. MSI 980Ti Lightning – Tomb Raider (SGB)
  • 10. MSI 980Ti Lightning – Batman Arkham Origins (SGB)
  • 11. MSI 980Ti Lightning – Battlefield 4 (RWB)
  • 12. MSI 980Ti Lightning – Assassins Creed: Black Flag (RWB)
  • 13. MSI 980Ti Lightning – Call of Duty: Ghosts (RWB)
  • 14. MSI 980Ti Lightning – Crysis 3 (RWB)
  • 15. MSI 980Ti Lightning – Witcher 3 (RWB)
  • 16. MSI 980Ti Lightning – Temperature, Noise, and Power Analysis
  • 17. MSI 980Ti Lightning – Overclocking
  • 18. MSI 980Ti Lightning – Performance Summary and TL;DR
  • 19. MSI 980Ti Lightning – Closing Statement
MSI GTX 980Ti Lightning: The Silent Assassin 52 MSI GTX 980Ti Lightning: The Silent Assassin 53 Quite honestly this video card is the most pleasant and yet frustrating video card to overclock. On the one hand that amazingly beefy power delivery system combined with three PCIe power connectors allows for amazingly stable voltages. Simply put you set it and you forget it as it is not going to bounce around like a tennis ball. When you then take those over-engineered components and give it a cooling system that rivals the best water based cooling solution in both the noise and temperature department this too makes things so much easier it is not even funny.
Then, and this really is the icing on the cake, when you take into account that MSI has worked closely with NVIDIA to provide Lightning owners with the absolute crème de la crème of 980Ti Maxwell cores…well it really is smile worthy. However, this is where the frustration comes into play. Because NVIDIA basically threatened MSI with never getting another GPU from them during the earlier Lightning days, this card – just like the 780Ti has been handicapped in the voltage department. Basically you will not be able to push any higher voltage on this card than you would on a reference model. That is so damn frustrating and would be like owning a Mclaren F1 but never being allowed to take it out 3rd…as the higher gear slots on the shifter have been welded shut. This is why we only reached a boost rate of 1,505Mhz. Getting this was extremely easy, crank the voltage all the way and start playing…which did not take all that long to dial in. Of course, this is still a 40% overclock over reference levels, but we know this highly binned core could have done even better.
Now do not get us wrong this is not MSI’s fault, they did try to get this artificial limitation removed for the Lightning series…and NVIDIA refused to negotiate in good faith. When being faced with what is tantamount to blackmail we cannot fault MSI for taking this hit and protecting their long term interest. Instead the blame almost solely rests on the shoulders of NVIDIA and their shortsightedness…and the rest being AMDs fault for not being able to compete in the ultra-high-end (the Fury series is good…but no Lightning). We all know that if NIVIDIA had true competition in this area they probably would be a lot less shortsighted about working with manufactures like MSI on their ‘special’ models.
On the positive side, if you are handy with a firmware hack…or even just a soldering iron you can get around this limitation and really crank things wide open. We personally did not feel the need for this as MSI will null and void your warranty if you do either.
Also on the positive side MSI gives you RAM voltage options that usually are only in the realm of hardware mods! This allows for downright insane overclocking on the RAM side of the equation…and really will come down to be how far you are willing to push things. For us we are a bit on the conservative side and while the RAM certainly was capable of even higher (we had it in the 8700 range before quickly scaling back to long term survivable levels)…we felt getting an effective speed of 8,344Mhz was ‘good enough’. After all this is a full 1,344MHz above reference speeds (an 19% overclock!) and this pushes the memory bandwidth from 336.5GB/s all the way to 400.5GB/s!MSI GTX 980Ti Lightning: The Silent Assassin 54 MSI GTX 980Ti Lightning: The Silent Assassin 55
Page 17 of 19
MSI R7 370 Gaming 2G
MSI Presents SUPRIM X 3090 3080 3070 Graphics Cards
November 20, 2020
Seagate SkyHawk 14TB Review
